    Can't find "scripts" field in /MagicMirror/modules/MMM-Todoist/package.json
    9 Posts 2 Posters 652 Views 2 Watching
    • D
      DarthWerner
      Hi Community,
      I’m having some trouble with my Todoist Module in MM since iI updated The module this week. MM and the Module itself are the latest release version and I get this message after my update:
      Can’t find “scripts” field in /MagicMirror/modules/MMM-Todoist/package.json
      Anyone else having problems like this?
      Would be happy to get some help with this .
      Thank you in advance
        sdetweil @DarthWerner
        @DarthWerner can you tell us WHEN you get that message?
        during npm install?
        If so, edit package.json
        And add this before the “dependencies”: line
        "scripts":{},
        Also can you show the output of
        node -v
        D 1 Reply Last reply
        • D
          DarthWerner @sdetweil
          Thank you Sam,
          I did it like this:
          “homepage”: “https://github.com/cbrooker/MMM-Todoist#readme”,
          “scripts”:{},
          “dependencies”: {
          “axios”: “^1.6.0”,
          “showdown”: “^2.0.1”
          and it tells me now that the install-mmm is missing.
          *wb@MagicMirror:~/MagicMirror/modules/MMM-Todoist $ sudo git pull && node --run install-mm
          Already up to date.
          Missing script: “install-mm” for /home/wb/MagicMirror/modules/MMM-Todoist/package.json
          Available scripts are:
          wb@MagicMirror:~/MagicMirror/modules/MMM-Todoist $ node -v
          v22.14.0*
          All I did was a Module Update as I did many times before.
            @DarthWerner
            Is for MagicMirror itself, not a module
            For a module it would be
            git pull && npm install
            • D
              @sdetweil said in Can't find "scripts" field in /MagicMirror/modules/MMM-Todoist/package.json:
              Thank you Sam,
              I think we’re running into a version problem:
              npm error code EBADENGINE
              npm error engine Unsupported engine
              npm error engine Not compatible with your version of node/npm: magicmirror@2.34.0
              npm error notsup Not compatible with your version of node/npm: magicmirror@2.34.0
              npm error notsup Required: {“node”:“>=22.21.1 <23 || >=24”}
              npm error notsup Actual: {“npm”:“11.3.0”,“node”:“v22.14.0”}
                @DarthWerner but you are supposed to be in the module folder
                • D
                  Yes, I’ve been in the modules folder when I did the git pull and npm install.
                  S 2 Replies Last reply
                    @DarthWerner in the MMM-Todoist folder right?
                      @DarthWerner but I think you may have messed up MagicMirror
                      Use my upgrade script with force instead of apply as the parm
                      See https://github.com/sdetweil/MagicMirror_scripts
