    Where to buy good two way mirrors ?
    86 Posts 33 Posters 195.4k Views 31 Watching
    • MitchfarinoM Offline
      Mitchfarino Module Developer
      @evos how big is the acrylic?
      I’ve seen on larger sizes the image reflected becomes distorted
        bibi @Bangee
        @Bangee Hi! did you ordered your mirror from this company finally? do you recommand? with which specs did you ordered?
        • BangeeB Offline
          Bangee Module Developer
          I’ve ordered there different pices of mirrors. 12%, 4mm and 20%.
            bibi @Bangee
            @Bangee thx for reply. which specs your recommand? i will call them tmrw :)
              bibi @bibi
              @bibi by the way i will use a 24" monitor. It would be very nice if you can advise me the size and best mirror specs to place my order :)
              • BangeeB Offline
                https://forum.magicmirror.builders/topic/117/bangee-s-mirror/16
                This one is also built with a 24" Monitor and a 12 %, 4mm Mirror.
                I would recommend this one.
                B 2 Replies Last reply Reply Quote 3
                  bibi @Bangee
                  @Bangee Thx you very much! - your help is much appriciated !
                    bibi @Bangee
                    @Bangee By the way your are from Swiss i guess? you speak french tho?
                    • BangeeB Offline
                      @bibi I wish I could, I understand a still a lot, but I don’t use it anymore…
                      I’m from the german part of Switzerland, close to Zurich.
                        I’ve just received the attached document regarding this acrylic - http://www.cutplasticsheeting.co.uk/mirrored-sheeting/two-way-acrylic-mirror
                        • 6
                        • 7
                        • 8
                        • 9
                        • 6 / 9
