    Where to buy good two way mirrors ?
    86 Posts 33 Posters 199.4k Views 31 Watching
      jeremy_fr @KirAsh4
      @KirAsh4 Hi! I don’t understand how you get 2,000$ for a 22x15cm glass on this site.
      When I make a simulation, I get something about 25$.
      Did I miss something?
      Thanks!
      MariaHTM 1 Reply Last reply Reply Quote 0
      • MariaHTM Offline
        MariaHT @jeremy_fr
        @jeremy_fr It should come to around $16.67 for that size mirror. Or we have 8" x 8" samples that can be cut down. Hope that helps!
          dajohn @Try2Fly
          @Try2Fly how is your plexiglass mirror if you put it in bright room? Thinking of ordering at doktor-plexiglas as well.
          • T Offline
            Try2Fly @dajohn
            @dajohn in bright rooms it works great. I had it hanging in a darker place, So the refection was not much. So took it off after a while.
            Also as it is plexiglass, if you order a large mirror the reflection might distort a bit. Mine was about 30x40 cm which was ok.
              dajohn @Try2Fly
              @Try2Fly thanks for the reply! Good point about the size. I’m planning a larger size (about 50 x 80 cm) so maybe better to go for glass.
                makinshaw @Davepre
                @Davepre did you find a good place in London in the end? I’m trying to build some MMs for Christmas and need to get some glass!
                • 5 / 5
