    npm start error?
    13 Posts 5 Posters 11.0k Views 5 Watching
    • L Offline
      longod
      I realized that it is telling me to go to a different log now when I do npm start, which is npm ERR! /home/pi/.npm/_logs/2017-04-27T15_23_04_547Z-debug.log. In there it gives me this message:
      1 verbose cli [ '/opt/nodejs/bin/node', '/usr/local/bin/npm', 'start' ]
      2 info using npm@4.5.0
      3 info using node@v7.7.1
      5 info lifecycle magicmirror@2.1.1~prestart: magicmirror@2.1.1
      6 silly lifecycle magicmirror@2.1.1~prestart: no script for prestart, continuing
      7 info lifecycle magicmirror@2.1.1~start: magicmirror@2.1.1
      8 verbose lifecycle magicmirror@2.1.1~start: unsafe-perm in lifecycle true
      9 verbose lifecycle magicmirror@2.1.1~start: PATH: /opt/nodejs/lib/node_modules/npm/bin/node-gyp-bin:/home/pi/MagicMirror/node_modules/.bin:/usr/local/sbin:/usr/local/$
      10 verbose lifecycle magicmirror@2.1.1~start: CWD: /home/pi/MagicMirror
      11 silly lifecycle magicmirror@2.1.1~start: Args: [ '-c', 'sh run-start.sh' ]
      12 info lifecycle magicmirror@2.1.1~start: Failed to exec start script
      13 verbose stack Error: magicmirror@2.1.1 start: `sh run-start.sh`
      13 verbose stack spawn ENOENT
      13 verbose stack     at ChildProcess. (/opt/nodejs/lib/node_modules/npm/lib/utils/spawn.js:33:16)
      13 verbose stack     at emitTwo (events.js:106:13)
      13 verbose stack     at ChildProcess.emit (events.js:194:7)
      13 verbose stack     at maybeClose (internal/child_process.js:899:16)
      13 verbose stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:226:5)
      14 verbose pkgid magicmirror@2.1.1
      15 verbose cwd /home/pi/MagicMirror
      16 verbose Linux 4.4.50+
      17 verbose argv "/opt/nodejs/bin/node" "/usr/local/bin/npm" "start"
      18 verbose node v7.7.1
      19 verbose npm  v4.5.0
      20 error file sh
      21 error code ELIFECYCLE
      22 error errno ENOENT
      23 error syscall spawn
      24 error magicmirror@2.1.1 start: `sh run-start.sh`
      24 error spawn ENOENT
      25 error Failed at the magicmirror@2.1.1 start script 'sh run-start.sh'.
      25 error Make sure you have the latest version of node.js and npm installed.
      25 error If you do, this is most likely a problem with the magicmirror package,
      25 error not with npm itself.
      25 error Tell the author that this fails on your system:
      25 error     sh run-start.sh
      25 error You can get information on how to open an issue for this project with:
      I’m lost on what to do next…
        adil
        Hi @longod, I have just installed MM on my Rpi 0 and I’m facing the exact same issue as you. Did you finally find the solution ??
        Thanks!
          adil @adil
          @adil It looks like the issue was linked to missing modules like clock.
          After I went to the vendor folder and installed using npm (see command below), I was able to launch MM successfully.
          cd ~/MagicMirror/vendor
          npm install
