    Pir Sensor - Screen switches on and off instantly
    2 Posts 2 Posters 1.5k Views 2 Watching
    • V Offline
      vicdilou
      Hi everybody.
      I finally managed to operate my pir sensor but the problem is that when I am in front of the sensor it captures me for 1 second and and I get more for 5 seconds and so on
      How can I fix this?
      Thank you !
      • O Offline
        Oliver_Tooth
        You should have two small dials on the sensor, one of these relates to the ‘time on’. Try turning that to full and see if that helps.
        On a side note, did you run into any issues during install with the node expecting a different version to the one installed?
