    Plex Now Playing and Phone Notifications
    1 Posts 1 Posters 1.2k Views 2 Watching
    • M
      mandy3d
      All my other modules work and my mirror is functioning. I’ve tried installing phone_notifications multiple times. It will work for a short while. However, after just a little while. It locks up and no notifications will load. The only way to get it to work again is to restart npm which is rather strange. I used the basic module configuration from the readme.
      Plex Now Playing… I have the server address in the way it should. I know the address works locally. I’m using the local server address. I didn’t feel like I need the remote one since I’m on the same network correct?
      I installed the parser like it asks.
      Here’s my config for the Plex Now Playing…
                  module: 'MMM-PlexNowPlaying',
                  disabled: false,
                  position: 'bottom_right',
                      serverURL: 'http://local_Address/:32400',
                      updateInterval: 10 * 1000,  // how often to poll for song chang$
                      delayCount: 5,  // how many empty queries before deciding we ar$
                      delayInterval: 60 * 1000,  // how often to poll for new listeni$
                      animationSpeed: 1000
      Are these issues related to the known Electron issue?
      This is my error log…
      npm ERR! missing script: start
      0|mm       |
      0|mm       | npm ERR! A complete log of this run can be found in:
      0|mm       | npm ERR!     /home/pi/.npm/_logs/2017-05-24T01_15_59_889Z-debug.log
      0|mm       | npm ERR! code ELIFECYCLE
      0|mm       | npm ERR! errno 1
      0|mm       | npm ERR! magicmirror@2.1.1 start: `sh run-start.sh`
      0|mm       | npm ERR! Exit status 1
      0|mm       | npm ERR!
      0|mm       | npm ERR! Failed at the magicmirror@2.1.1 start script.
      0|mm       | npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
      0|mm       |
      0|mm       | npm ERR!     /home/pi/.npm/_logs/2017-05-24T01_18_58_612Z-debug.log
