    Home made 60" touch Magic Mirror
    41 Posts 13 Posters 74.9k Views 16 Watching
      scooter
      Hi I started my own photo booth hire business ,which Magic Mirrors are taking over,I couldn’t afford the £6000 to buy a magic mirror ,so I built my own for £1500 ,iam now doing Weddings with it ,and making a living from something I built at home https://youtu.be/GKSGxAdq22k
      MariaHTM K 2 Replies Last reply Reply Quote 1
      • MariaHTM Offline
        MariaHT @scooter
        @scooter Nice! Looks so good! I’ve spoken with a few DIYers that plan on shooting through the mirror for their booth. Wedding photography is my second job. It is always inspiring to hear others following their passion and making a living from it. Where did you get the IR touch display frame? If you don’t mind?
          scooter @MariaHT
          Hi Maria ,2 point touch frame from Ali Express £120 60" smart tv ,dont use 50/50 mirror glass you see too much tv thru it ,70/30 perfect,social booth software now includes magic mirror upgrade ,hope that helps ,Jim
          Hi Maria 2 point touch frame from Ali express £120.50/50 mirror glass lets too much tv thru usr 70/30 perfect,social booth software now upgraded to magic mirror ,any more questions please ask. Jim0_1498722485676_100_9738.JPG
            scooter
            Info sent by Pm that might be of interest …Quote …Just a standard clear 6mm wide led strip ,it goes in the frame where glass is supposed to go ,as the mirror is in and flush with the main structure on top of the tv cushioned with foam ,the type of foam used in camping ground sheets .tv is also cushioned in same material ,so no vibration gets thru to tv or mirror,I think 2 touch is fine for the software iam running and keeps it simple ,perhaps more than one person can sign their pictures at a time using higher touch ,but then you have half a dozen kids touching the screen at the same time ,yes it was the same price i got mine obviously its got to be toughened.The IR frames seem to work well driver free with windows 10 ,would’nt work with windows 7,make sure the tv has a good remote pick up .the cushioning should be cut away to expose the tv IR receiver so the remote can hit it thru the glass.Lap top has to be set to portrait when it detects an Hdmi output ,returning to normal when you switch the mirror off,start up laptop then tv .hope this helps,I got the 60" he has only 55" left http://www.ebay.co.uk/itm/Seiki-SE55FO04UK-55-Inch-Smart-LED-1080p-Full-HD-Freeview-HD-TV-3-HDMI-New-from-/302303678580?epid=1360567275&hash=item4662b41074:g:~tcAAOSwiONYLJTW
            • MariaHTM Offline
              MariaHT
              Thanks for the quick reply! I’m excited to work on a touch screen smart mirror in the future :) I appreciate the help!
              • O Offline
                orgist
                Hello you did a very good job. I live in Istanbul and I do research to do the same. You can write the materials you use.
                • C Offline
                  cyberphox
                  currently building a Magic Mirror booth as well…have the tv, IR frame, glass and camera…willing to share some construction photos?
                    scooter
                    No Probs here are some pics ,you can see the way i built the frame ,Cladded the ply with high gloss black formica ,use Bond It high impact adhesive ,dont leave glue to long as it grabs the formica ,mine has room for a cy printer at bottom,and shelf for laptop,its a heavy beast lol.![0_1499798576168_WP_20170227_003.jpg](Uploading 100%)
                      scooter
                      Latest promo video showing the home made magic mirror https://youtu.be/9k1UUVl08bo
                        MMScreen
                        Amazing job Jim! It looks absolutely stunning!!! May I ask a few questions?
                        1. Firstly could you help me to know where to purchase the glass from?
                        2. Secondly, what material did you use to make the flight case, Astroboard? Or another material? 7mm?
                        3. Lastly, your frame looks amazing! Is that possible to buy online?
                        Thank you in advance!
                        Martin
                        • C Offline
                          cyberphox @scooter
                          @scooter pics aren’t showing
                            scooter @MMScreen
                            Hi Martin 70/30 mirror view from http://www.mirrorsandglass.co.uk
                            I used 7mm ply as that was what i had,no you must build your own frame ,i will try to post a pic of mine.
                            regards
                              MMScreen @scooter
                              @scooter Thank you Jim. I’ve ordered my IR now but not sure about how to build a frame. Did you purcase the frame material from a website online that you could share? Thanks again in advance, very much appreciated for all of your help.
                                MMScreen
                                Hi Scooter, I hope you’re well.
                                I haveing a hard time trying to find the material to build a frame. I would like to build a frame like this one as shown here: https://www.photobooths.co.uk/product/white-silver-magic-mirror-frame/ however can’t find the material anywhere online! It is a very wide frame, approx. 90mm width (very much wider than normal photo frames).
                                Any idea where I can get a length of this material to make into a frame?
                                Any help massively appreciated!!
                                Thanks,
                                Martin.
                                  mirroronthewall
                                  Looks great scooter!
                                  Did you use the Pilkington 6mm MirroView mirror or 6mm Two-Way Mirror?
                                  Also is it possible to mount the camera behind the mirror?
                                  Cheers!
                                  • H Offline
                                    Hoosierdad
                                    @scooter is there anyway you can take pictures / close ups of the LED strip and frame. I just ordered my glass and IR frame curious how you put yours together.
                                    also how do you secure the glass and IR fram in the back of the picture frame. thanks
                                    • K Offline
                                      krisalexroberts @scooter
                                      @scooter did you write the software yourself?
                                      • C Offline
                                        cyberphox
                                        Seems Scooter is MIA
                                        • Scatha20S Offline
                                          Scatha20
                                          Any updates ? I want to build my own Magic Mirror Photobooth, but It hard to find accurate info. Any help?
                                          • C Offline
                                            cyberphox @Scatha20
                                            @scatha20 Got mine up and running…
                                            Scatha20S 1 Reply Last reply Reply Quote 0
                                            • 1 / 3
