    How to add modules. For absolute beginners.
    91 Posts 16 Posters 144.7k Views 24 Watching
      sdetweil @fsne04
      @fsne04 weather u need to sign up and get an api token just for you…
      • F Offline
        fsne04 @sdetweil
        I did, maybe I did not copy it correctly. I will check.
        So how do I start a new topic/question and get nice/helpful people like you to answer? I have a few questions on the Remote Control module configuration also.
          sdetweil @fsne04
          @fsne04 see https://forum.magicmirror.builders/topic/4231/how-to-add-modules-for-absolute-beginners/73?page=8
          • F Offline
            fsne04 @sdetweil
            In the headder, I see: Unread, Recent, Tags, Unsolved, Solved, Users, Groups, Repository, Documents, Donate, Join Channel… I am sure it’s there, but I don’t see a New Topic, or create Topic button.
            Thank you for your help today, Sam! Greatly appreciate your time.
            Best regards,
            Frank
              sdetweil @fsne04
              @fsne04 when I push unread, I see
                ashishtank Module Developer @fsne04
                @fsne04 if you check the code of MMM-Screent cast @ https://github.com/kevinatown/MMM-Screencast/blob/master/constants.js then there is no position which supports fullscreen_below.
                you need to set one of the below value as per documentation of the module
                const POSITIONS = {
                  bottomRight: 'bottomRight',
                  bottomCenter: 'bottomCenter',
                  bottomLeft: 'bottomLeft',
                  center: 'center',
                  topRight: 'topRight',
                  topCenter: 'topCenter',
                  topLeft: 'topLeft',
                  top_bar: 'topRight',
                  top_left: 'topLeft',
                  top_center: 'topCenter',
                  top_right: 'topRight',
                  upper_third: 'topRight',
                  middle_center: 'center',
                  lower_third: 'bottomCenter',
                  bottom_left: 'bottomLeft',
                  bottom_center: 'bottomCenter',
                  bottom_right: 'bottomRight',
                  bottom_bar: 'bottomCenter'
                  ashishtank Module Developer @ashishtank
                  @fsne04 Here it checks for the position value (edited my answer above).
                    mishu28nmv
                    Hello guys. Absolute beginner in coding. I would like to make my own module with Flight prices.
                    As default I will have:
                    token: "MyToken",
                    api_host: "travelpayouts-travelpayouts-flight-data-v1.p.rapidapi.com",
                    api_key: "MyApiKey"
                    And as options I will have:
                    origin: "AAA",//Airport 3-Letter code
                    currency: "EUR",
                    depart_date: "2022-06-12",//format YYYY-MM-DD
                    return_date: "2022-06-19",//format YYYY-MM-DD
                    destination: "BBB"//Airport 3-Letter code
                    Is there anyone who can create a right code (module) for this situation? If this is too stupid to ask, or if this already exists, please let me know :(
                    • C Offline
                      cgillinger
                      Hi! I know this thread is quite old, but since I’m a complete noob, and I’ve followed the specific guide I didn’t want to spam the forum with a new thread.
                      I’ve tried adding this basic module, but the effect is always that the MM wont start.
                      I’m on Windows 10 (using a Surface Pro 4).
                      I’m using Notepad++
                      With the default installation, MM works using a browser.
                      This is how my config looks after adding the Jeopardy module:
                      This is the error output from CMD:
                      What am I doing wrong?
                        sdetweil @cgillinger
                        @cgillinger this module suffers from this problem
                        https://forum.magicmirror.builders/topic/15778/fix-for-black-screen-in-2-16-and-later/1
                        but the output looks different so
                        go to the module folder and do
                        npm init -y
                        npm install request
                        • 6
                        • 7
                        • 8
                        • 9
                        • 10
                        • 9 / 10
