    How to add modules. For absolute beginners.
    91 Posts 16 Posters 160.3k Views 24 Watching
    • C Offline
      Chrisflex
      @Mykle1 said in How to add modules. For absolute beginners.:
      There isn’t one because the only difference is the path to your config folder. So, navigate to your config folder (inside the MagicMirror folder) and open it. If you don’t find a config.js file there then you need to copy and paste the config.js.sample file and rename the copy to config.js. Once you have made or found a config.js file then you can just follow the tutorial from there.
      Thank you very much, I will follow the instructions and see how I go.
        Dask
        First of all I would like to say thank you for the step by step tutorial. It helped me a lot and I can now install some MM modules.
        I do have a question though, I don’t really understand how to add dependencies. You say add it to the folder via the terminal??? I tried this on your PilotWX module but I don’t really know how to do it. I thought I did it eventually but nothing come up in my MM. I have also copied and pasted the other part into config.
        Any help would be appreciated.
        BKeyportB Mykle1M 2 Replies Last reply Reply Quote 0
        • BKeyportB Offline
          BKeyport Module Developer @Dask
          @Dask Dependencies are on a case by case basis. In many cases, it’s as simple as installing it into npm, by using npm install
          In some cases, however, there’s additional outside programs or such that’s not covered by the npm install method. I’ve yet to see a module that requires additional software not include an installer script to take care of that for you, generally the readme will tell you if that’s the case.
          Bottom line, follow the instructions in the readme.
            Dask
            BKeyport
            Thank you for your reply. But I’m sorry to say I still don’t get it so let me explain my problem a little better.
            The module says “npm install in your ~/MagicMirror/modules/MMM-PilotWX directory.” How do I do this. I tried going into ~/MagicMirror/modules/MMM-PilotWX but that command is not recognised in the terminal. How do I get into the correct place to add npm install.
            Sorry if I am being stupid but this is all new to me.
            S BKeyportB Mykle1M 3 Replies Last reply Reply Quote 0
              sdetweil @Dask
              @Dask you should use a terminal window, and cd ~/MagicMirror/modules/??? where ??? is the module name
              and then type
              npm install
              ONLY of there is a file called package.json present in the module folder
              (npm install reads that file)
              and hit enter
              node and npm are installed system wide so there should be no problem
              • BKeyportB Offline
                @Dask I’ll walk you through this one, same for most non-scripted modules:
                assuming MagicMirror is installed with defaults:
                1. go to your modules directory: cd ~/MagicMirror/modules/
                2. Clone the module to get it on your machine: git clone https://github.com/mykle1/MMM-PilotWX.git
                3. go to the module’s directory: cd MMM-PilotWX
                4. install the dependencies npm install
                5. configure, and restart magic mirror.
                Cheers.
                  Mykle1 Project Sponsor Module Developer @Dask
                  @Dask said in How to add modules. For absolute beginners.:
                  You’re welcome, mate.
                    @Dask
                    I haven’t touched MMM-PilotWX in some time so I loaded it up. All is well.
                    This would be your default config entry. Once you have it up an running you can make your changes.
                    	disabled: false,
                    	module: "MMM-PilotWX",
                    	position: "top_left",         // for mode: "Static",  bottom_bar for mode: "Rotating",
                    		ICAO: "KJFK,EGLL,UUDD,EDDT,RJAA,ZBAA,LFPG,LIRF", // list of INTL ICAO's
                    		colorCode: "Alternative", // Standard or Alternative
                    		mode: "Static",           // Static (List) or Rotating (one by one)
                    		mostRecentPerStation: true,	//limits observations to 1 per station
                    		sym: "@",                 // @ or / (Separator for Wind speed and direction)
                    		tempUnits: "C",		   // C or F (F converted from C)
                    		measure: "SM",            // SM or KM (KM converted from SM data)
                    		time: "Local",            // Zulu or Local (observation time)
                    		maxWidth: "100%",         // 100% for mode: Rotating, approx 300px for mode: Static
                    		useAltHeader: true,	  // Use alternative header
                    		useHeader: false,
                    		header: "",
                      Dask
                      Thank you all for the help. I am slowly getting it. Honest.
                        Dask
                        Mykle! I have the PilotMX instlled and working on the bottom bar with my chosen 2 airports but it takes up the full width of the screen. Can I make it narrower. I changed the maxWidth to 300px but it is still all the way across.
                        • BKeyportB Offline
                          @Dask bottom bar is designed to do exactly that. you’d be better to use bottom_left, bottom_right, or bottom_center (or is it middle, I don’t recall, I keep my config organized by the regions, so I get reminded when I redesign)
                          • T Offline
                            TheSij @Mykle1
                            @Mykle1 - thanks for this guide. I promise I’ve studied it through and read the additional helpful comments that other contributors have made. However, I’ve having trouble adding the MMM-PrayerTime module to config.js. When I add the module and MM restarts, it shows blank and an error telling me to create a config file. Grateful for pointers on where I’m going wrong (please see code below. I’ve hidden any personal information). Thanks.
                            To note that without the entry to the MMM-PrayerTime module added to config.js Magic Mirror runs fine with the other modules.
                            			module: "alert",
                            			module: "updatenotification",
                            			position: "top_bar"
                            			module: "clock",
                            			module: "MMM-PrayerTime",
                            			position: "top_left",	// This can be any of the regions. Best result is in the top_left/top_right.
                            				apiVersion: "1.0", // please, leave unchanged. reserved for future use.
                            				lat: xx.xxxxxxx, // latitude of your position (city)
                            				lon: -x.xxxxxxx, // longitude of your position (city)
                            				timezone: Europe/London, // please refer to http://php.net/manual/en/timezones.php
                            				timeFormat: 24,
                            				method: 5,
                            				playAdzan: ["fajr", "dhuhr", "asr", "maghrib", "isha"],
                            				notDisplayed: ["midnight", "sunset"],
                            				useUpdateInterval: true,
                            				updateInterval: 86400 * 1000, // How often do you want to fetch new praying time? (milliseconds)
                            				animationSpeed: 2.5 * 1000, // Speed of the update animation. (milliseconds)
                            				language: config.language,
                            				showAdzanAlert: true,
                            				showTomorrow: true,
                            				vertical: true, // set false for horizontal view
                            				alertTimer: 15000
                            			header: "UK Holidays",
                            						symbol: "calendar-check",
                            						url: "webcal://www.calendarlabs.com/ical-calendar/ics/75/UK_Holidays.ics"					}
                            			module: "currentweather",
                            				locationID: "2643743", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
                            				appid: "xxxxxxxxxxxxxxxxxxxxxxxxxxxxx"
                            			module: "weatherforecast",
                            			header: "Weather Forecast",
                            				appid: "xxxxxxxxxxxxxxxxxxxxxxxxxxxxxx"
                            			module: "newsfeed",
                            			position: "bottom_bar",
                            				feeds: [
                            						title: "New York Times",
                            						url: "https://rss.nytimes.com/services/xml/rss/nyt/HomePage.xml"
                            						title: "BBC World News",
                            						url: "http://feeds.bbci.co.uk/news/world/rss.xml"
                            						title: "Reddit",
                            						url: "https://www.reddit.com/r/worldnews/.rss"
                            						title: "Buzzfeed",
                            						url: "https://www.buzzfeed.com/world.xml"
                            						title: "Al Jazeera",
                            						url: "http://www.aljazeera.com/xml/rss/all.xml"
                            				showSourceTitle: true,
                            				showPublishDate: true,
                            				broadcastNewsFeeds: true,
                            				broadcastNewsUpdates: true
                              sdetweil @TheSij
                              @TheSij ok, general rules for config values
                              thing to the right of :
                              if numeric or true/false
                              no quotes
                              otherwise quoted, single or double doesn’t matter as long as both ends are the same
                              exception here, if the string is config.something (yours has config.language)
                              then not quoted, as this means use the value of that item from this config
                              so, your timezone is text, but has no quotes.
                              I assume u xx the lat/long so we won’t know where u are
                              T 1 Reply Last reply Reply Quote 1
                              • T Offline
                                TheSij @sdetweil
                                @sdetweil. Thanks, Sam. That’s helpful to explain the general rules.
                                I’ve made a slight amendment - I figured that the timezone parameters was not correctly entered (see below - this time just showing the modules before and after). To answer your last point, I did remove the lat/lon values to hide my exact location (this time I’ve put in made-up numbers). With the slight amendment to the code, it’s still not working - do you think it’s the ‘timezone’ value that is causing the problem? I’ve not made any changes to the other modules.
                                				appid: "1ab234c567defgh89012ij34k56l78mn"
                                			module: 'MMM-PrayerTime',
                                			position: 'top_left',	// This can be any of the regions. Best result is in the top_left/top_right.
                                				apiVersion: '1.0', // please, leave unchanged. reserved for future use.
                                				lat: 12.3456789, // latitude of your position (city)
                                				lon: -0.1234567, // longitude of your position (city)
                                				timezone: date_default_timezone_set('Europe/London'), // please refer to http://php.net/manual/en/timezones.php
                                				timeFormat: 24,
                                				method: 5,
                                				playAdzan: ['fajr', 'dhuhr', 'asr', 'maghrib', 'isha'],
                                				notDisplayed: ['midnight', 'sunset'],
                                				showTomorrow: true,
                                				alertTimer: 15000
                                			module: "newsfeed",
                                				feeds: [
                                						title: "Reddit",
                                						title: "Buzzfeed",
                                  sdetweil @TheSij
                                  @TheSij yes, still timezone., that syntax says call a function named date_default_timezone_set
                                  but I don’t know where that would be.
                                  just comment out that one line. add // at the start of the line
                                  • T Offline
                                    TheSij @sdetweil
                                    @sdetweil - thanks! Unfortunately, still no luck on adding // at the start of the line, or after ‘timezone:’. According to the module creator, the timezone is a required field. I went to the php website that the module creator refers to, but it just doesn’t make sense to me - the coding information on that website is vast and much too advanced for me. I may have to abandon my desire to add this particular module. :-(
                                      @TheSij said in How to add modules. For absolute beginners.:
                                      Don’t give up! I just installed this to test it for you. I can see why it was confusing for you but it does work. Here is my config entry. Use it as a template for yours, replacing your info for mine. The following screenshot shows it working.
                                      		position: 'top_center',	// This can be any of the regions. Best result is in the top_left/top_right.
                                      			lat: myLat, // latitude of your position (city)
                                      			lon: myLong, // longitude of your position (city)
                                      			timezone: 'Europe/London', // please refer to http://php.net/manual/en/timezones.php
                                      //			timeFormat: 24,
                                      			method: 5,
                                      	//		language: config.language,
                                      			showTomorrow: true,
                                      			alertTimer: 15000
                                      S T 2 Replies Last reply Reply Quote 0
                                        sdetweil @Mykle1
                                        @Mykle1 thx!
                                        so the original problem was the timezone wasn’t quoted.
                                          @sdetweil said in How to add modules. For absolute beginners.:
                                          That and language: config.language, was causing an error. I simply commented it out and the module uses the config language by default. :-)
                                          Edit: Oh, and timeFormat: 24, in the module’s config entry, as well. Again, I commented it out as it was redundant.
                                            sdetweil @Mykle1
                                            @Mykle1 yep, didn’t see that right… because the javascript source code processor is in the process of reading the config object definition
                                            var config= {
                                            the config object is not yet defined. so config.language cannot exist (yet)
                                            but the timeFormat can be present AND redundant and not cause a startup error
                                            • 2 / 5
