    How to add modules. For absolute beginners.
    91 Posts 16 Posters 162.4k Views 24 Watching
      Dask
      First of all I would like to say thank you for the step by step tutorial. It helped me a lot and I can now install some MM modules.
      I do have a question though, I don’t really understand how to add dependencies. You say add it to the folder via the terminal??? I tried this on your PilotWX module but I don’t really know how to do it. I thought I did it eventually but nothing come up in my MM. I have also copied and pasted the other part into config.
      Any help would be appreciated.
      BKeyportB Mykle1M 2 Replies Last reply Reply Quote 0
      • BKeyportB Offline
        BKeyport Module Developer @Dask
        @Dask Dependencies are on a case by case basis. In many cases, it’s as simple as installing it into npm, by using npm install
        In some cases, however, there’s additional outside programs or such that’s not covered by the npm install method. I’ve yet to see a module that requires additional software not include an installer script to take care of that for you, generally the readme will tell you if that’s the case.
        Bottom line, follow the instructions in the readme.
          Dask
          BKeyport
          Thank you for your reply. But I’m sorry to say I still don’t get it so let me explain my problem a little better.
          The module says “npm install in your ~/MagicMirror/modules/MMM-PilotWX directory.” How do I do this. I tried going into ~/MagicMirror/modules/MMM-PilotWX but that command is not recognised in the terminal. How do I get into the correct place to add npm install.
          Sorry if I am being stupid but this is all new to me.
          S BKeyportB Mykle1M 3 Replies Last reply Reply Quote 0
            sdetweil @Dask
            @Dask you should use a terminal window, and cd ~/MagicMirror/modules/??? where ??? is the module name
            and then type
            npm install
            ONLY of there is a file called package.json present in the module folder
            (npm install reads that file)
            and hit enter
            node and npm are installed system wide so there should be no problem
            • BKeyportB Offline
              @Dask I’ll walk you through this one, same for most non-scripted modules:
              assuming MagicMirror is installed with defaults:
              1. go to your modules directory: cd ~/MagicMirror/modules/
              2. Clone the module to get it on your machine: git clone https://github.com/mykle1/MMM-PilotWX.git
              3. go to the module’s directory: cd MMM-PilotWX
              4. install the dependencies npm install
              5. configure, and restart magic mirror.
              Cheers.
                Mykle1 Project Sponsor Module Developer @Dask
                @Dask said in How to add modules. For absolute beginners.:
                You’re welcome, mate.
                  @Dask
                  I haven’t touched MMM-PilotWX in some time so I loaded it up. All is well.
                  This would be your default config entry. Once you have it up an running you can make your changes.
                  	disabled: false,
                  	module: "MMM-PilotWX",
                  	position: "top_left",         // for mode: "Static",  bottom_bar for mode: "Rotating",
                  		ICAO: "KJFK,EGLL,UUDD,EDDT,RJAA,ZBAA,LFPG,LIRF", // list of INTL ICAO's
                  		colorCode: "Alternative", // Standard or Alternative
                  		mode: "Static",           // Static (List) or Rotating (one by one)
                  		mostRecentPerStation: true,	//limits observations to 1 per station
                  		sym: "@",                 // @ or / (Separator for Wind speed and direction)
                  		tempUnits: "C",		   // C or F (F converted from C)
                  		measure: "SM",            // SM or KM (KM converted from SM data)
                  		time: "Local",            // Zulu or Local (observation time)
                  		maxWidth: "100%",         // 100% for mode: Rotating, approx 300px for mode: Static
                  		useAltHeader: true,	  // Use alternative header
                  		useHeader: false,
                  		header: "",
                    Dask
                    Thank you all for the help. I am slowly getting it. Honest.
                      Dask
                      Mykle! I have the PilotMX instlled and working on the bottom bar with my chosen 2 airports but it takes up the full width of the screen. Can I make it narrower. I changed the maxWidth to 300px but it is still all the way across.
                      • BKeyportB Offline
                        @Dask bottom bar is designed to do exactly that. you’d be better to use bottom_left, bottom_right, or bottom_center (or is it middle, I don’t recall, I keep my config organized by the regions, so I get reminded when I redesign)
                        • T Offline
                          TheSij @Mykle1
                          @Mykle1 - thanks for this guide. I promise I’ve studied it through and read the additional helpful comments that other contributors have made. However, I’ve having trouble adding the MMM-PrayerTime module to config.js. When I add the module and MM restarts, it shows blank and an error telling me to create a config file. Grateful for pointers on where I’m going wrong (please see code below. I’ve hidden any personal information). Thanks.
                          To note that without the entry to the MMM-PrayerTime module added to config.js Magic Mirror runs fine with the other modules.
                          			module: "alert",
                          			module: "updatenotification",
                          			position: "top_bar"
                          			module: "clock",
                          			module: "MMM-PrayerTime",
                          			position: "top_left",	// This can be any of the regions. Best result is in the top_left/top_right.
                          				apiVersion: "1.0", // please, leave unchanged. reserved for future use.
                          				lat: xx.xxxxxxx, // latitude of your position (city)
                          				lon: -x.xxxxxxx, // longitude of your position (city)
                          				timezone: Europe/London, // please refer to http://php.net/manual/en/timezones.php
                          				timeFormat: 24,
                          				method: 5,
                          				playAdzan: ["fajr", "dhuhr", "asr", "maghrib", "isha"],
                          				notDisplayed: ["midnight", "sunset"],
                          				useUpdateInterval: true,
                          				updateInterval: 86400 * 1000, // How often do you want to fetch new praying time? (milliseconds)
                          				animationSpeed: 2.5 * 1000, // Speed of the update animation. (milliseconds)
                          				language: config.language,
                          				showAdzanAlert: true,
                          				showTomorrow: true,
                          				vertical: true, // set false for horizontal view
                          				alertTimer: 15000
                          			header: "UK Holidays",
                          						symbol: "calendar-check",
                          						url: "webcal://www.calendarlabs.com/ical-calendar/ics/75/UK_Holidays.ics"					}
                          			module: "currentweather",
                          				locationID: "2643743", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
                          				appid: "xxxxxxxxxxxxxxxxxxxxxxxxxxxxx"
                          			module: "weatherforecast",
                          			header: "Weather Forecast",
                          				appid: "xxxxxxxxxxxxxxxxxxxxxxxxxxxxxx"
                          			module: "newsfeed",
                          			position: "bottom_bar",
                          				feeds: [
                          						title: "New York Times",
                          						url: "https://rss.nytimes.com/services/xml/rss/nyt/HomePage.xml"
                          						title: "BBC World News",
                          						url: "http://feeds.bbci.co.uk/news/world/rss.xml"
                          						title: "Reddit",
                          						url: "https://www.reddit.com/r/worldnews/.rss"
                          						title: "Buzzfeed",
                          						url: "https://www.buzzfeed.com/world.xml"
                          						title: "Al Jazeera",
                          						url: "http://www.aljazeera.com/xml/rss/all.xml"
                          				showSourceTitle: true,
                          				showPublishDate: true,
                          				broadcastNewsFeeds: true,
                          				broadcastNewsUpdates: true
                            sdetweil @TheSij
                            @TheSij ok, general rules for config values
                            thing to the right of :
                            if numeric or true/false
                            no quotes
                            otherwise quoted, single or double doesn’t matter as long as both ends are the same
                            exception here, if the string is config.something (yours has config.language)
                            then not quoted, as this means use the value of that item from this config
                            so, your timezone is text, but has no quotes.
                            I assume u xx the lat/long so we won’t know where u are
                            • T Offline
                              TheSij @sdetweil
                              @sdetweil. Thanks, Sam. That’s helpful to explain the general rules.
                              I’ve made a slight amendment - I figured that the timezone parameters was not correctly entered (see below - this time just showing the modules before and after). To answer your last point, I did remove the lat/lon values to hide my exact location (this time I’ve put in made-up numbers). With the slight amendment to the code, it’s still not working - do you think it’s the ‘timezone’ value that is causing the problem? I’ve not made any changes to the other modules.
                              				appid: "1ab234c567defgh89012ij34k56l78mn"
                              			module: 'MMM-PrayerTime',
                              			position: 'top_left',	// This can be any of the regions. Best result is in the top_left/top_right.
                              				apiVersion: '1.0', // please, leave unchanged. reserved for future use.
                              				lat: 12.3456789, // latitude of your position (city)
                              				lon: -0.1234567, // longitude of your position (city)
                              				timezone: date_default_timezone_set('Europe/London'), // please refer to http://php.net/manual/en/timezones.php
                              				timeFormat: 24,
                              				method: 5,
                              				playAdzan: ['fajr', 'dhuhr', 'asr', 'maghrib', 'isha'],
                              				notDisplayed: ['midnight', 'sunset'],
                              				showTomorrow: true,
                              				alertTimer: 15000
                              			module: "newsfeed",
                              				feeds: [
                              						title: "Reddit",
                              						title: "Buzzfeed",
                                sdetweil @TheSij
                                @TheSij yes, still timezone., that syntax says call a function named date_default_timezone_set
                                but I don’t know where that would be.
                                just comment out that one line. add // at the start of the line
                                • T Offline
                                  TheSij @sdetweil
                                  @sdetweil - thanks! Unfortunately, still no luck on adding // at the start of the line, or after ‘timezone:’. According to the module creator, the timezone is a required field. I went to the php website that the module creator refers to, but it just doesn’t make sense to me - the coding information on that website is vast and much too advanced for me. I may have to abandon my desire to add this particular module. :-(
                                    @TheSij said in How to add modules. For absolute beginners.:
                                    Don’t give up! I just installed this to test it for you. I can see why it was confusing for you but it does work. Here is my config entry. Use it as a template for yours, replacing your info for mine. The following screenshot shows it working.
                                    		position: 'top_center',	// This can be any of the regions. Best result is in the top_left/top_right.
                                    			lat: myLat, // latitude of your position (city)
                                    			lon: myLong, // longitude of your position (city)
                                    			timezone: 'Europe/London', // please refer to http://php.net/manual/en/timezones.php
                                    //			timeFormat: 24,
                                    			method: 5,
                                    	//		language: config.language,
                                    			showTomorrow: true,
                                    			alertTimer: 15000
                                    S T 2 Replies Last reply Reply Quote 0
                                      sdetweil @Mykle1
                                      @Mykle1 thx!
                                      so the original problem was the timezone wasn’t quoted.
                                        @sdetweil said in How to add modules. For absolute beginners.:
                                        That and language: config.language, was causing an error. I simply commented it out and the module uses the config language by default. :-)
                                        Edit: Oh, and timeFormat: 24, in the module’s config entry, as well. Again, I commented it out as it was redundant.
                                          sdetweil @Mykle1
                                          @Mykle1 yep, didn’t see that right… because the javascript source code processor is in the process of reading the config object definition
                                          var config= {
                                          the config object is not yet defined. so config.language cannot exist (yet)
                                          but the timeFormat can be present AND redundant and not cause a startup error
                                          • T Offline
                                            TheSij @Mykle1
                                            @Mykle1 thanks to you and @sdetweil for helping me with this. It’s much appreciated. Deep down I’m reluctant to give up, because I don’t like quitting. I’ve literally just copied your config entry, and simply adding my own lat/lon figures. But now the MagicMirror shows up as a blank black screen and the window is named ‘Electron’, rather than ‘MagicMirror2’.
                                            I’m checking, double-checking and triple-checking and I can’t see where the discrepancy is compared to your entry. Could having too many modules be an issue? Can I also check - both of you have commented that the ‘timezone’ is causing an error, but your config entry doesn’t show that it’s commented out…?
                                            • 2 / 5
