    How to add modules. For absolute beginners.
    91 Posts 16 Posters 166.6k Views 24 Watching
      Dask
      Mykle! I have the PilotMX instlled and working on the bottom bar with my chosen 2 airports but it takes up the full width of the screen. Can I make it narrower. I changed the maxWidth to 300px but it is still all the way across.
      BKeyportB 1 Reply Last reply
      • BKeyportB
        BKeyport Module Developer @Dask
        @Dask bottom bar is designed to do exactly that. you’d be better to use bottom_left, bottom_right, or bottom_center (or is it middle, I don’t recall, I keep my config organized by the regions, so I get reminded when I redesign)
        • T
          TheSij @Mykle1
          @Mykle1 - thanks for this guide. I promise I’ve studied it through and read the additional helpful comments that other contributors have made. However, I’ve having trouble adding the MMM-PrayerTime module to config.js. When I add the module and MM restarts, it shows blank and an error telling me to create a config file. Grateful for pointers on where I’m going wrong (please see code below. I’ve hidden any personal information). Thanks.
          To note that without the entry to the MMM-PrayerTime module added to config.js Magic Mirror runs fine with the other modules.
          			module: "alert",
          			module: "updatenotification",
          			position: "top_bar"
          			module: "clock",
          			position: "top_left"
          			module: "MMM-PrayerTime",
          			position: "top_left",	// This can be any of the regions. Best result is in the top_left/top_right.
          				apiVersion: "1.0", // please, leave unchanged. reserved for future use.
          				lat: xx.xxxxxxx, // latitude of your position (city)
          				lon: -x.xxxxxxx, // longitude of your position (city)
          				timezone: Europe/London, // please refer to http://php.net/manual/en/timezones.php
          				timeFormat: 24,
          				method: 5,
          				playAdzan: ["fajr", "dhuhr", "asr", "maghrib", "isha"],
          				notDisplayed: ["midnight", "sunset"],
          				useUpdateInterval: true,
          				updateInterval: 86400 * 1000, // How often do you want to fetch new praying time? (milliseconds)
          				animationSpeed: 2.5 * 1000, // Speed of the update animation. (milliseconds)
          				language: config.language,
          				showAdzanAlert: true,
          				showTomorrow: true,
          				vertical: true, // set false for horizontal view
          				alertTimer: 15000
          			header: "UK Holidays",
          						symbol: "calendar-check",
          						url: "webcal://www.calendarlabs.com/ical-calendar/ics/75/UK_Holidays.ics"					}
          			module: "currentweather",
          				locationID: "2643743", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
          				appid: "xxxxxxxxxxxxxxxxxxxxxxxxxxxxx"
          			module: "weatherforecast",
          			header: "Weather Forecast",
          				appid: "xxxxxxxxxxxxxxxxxxxxxxxxxxxxxx"
          			module: "newsfeed",
          			position: "bottom_bar",
          				feeds: [
          						title: "New York Times",
          						url: "https://rss.nytimes.com/services/xml/rss/nyt/HomePage.xml"
          						title: "BBC World News",
          						url: "http://feeds.bbci.co.uk/news/world/rss.xml"
          						title: "Reddit",
          						url: "https://www.reddit.com/r/worldnews/.rss"
          						title: "Buzzfeed",
          						url: "https://www.buzzfeed.com/world.xml"
          						title: "Al Jazeera",
          						url: "http://www.aljazeera.com/xml/rss/all.xml"
          				showSourceTitle: true,
          				showPublishDate: true,
          				broadcastNewsFeeds: true,
          				broadcastNewsUpdates: true
            sdetweil @TheSij
            @TheSij ok, general rules for config values
            thing to the right of :
            if numeric or true/false
            no quotes
            otherwise quoted, single or double doesn’t matter as long as both ends are the same
            exception here, if the string is config.something (yours has config.language)
            then not quoted, as this means use the value of that item from this config
            so, your timezone is text, but has no quotes.
            I assume u xx the lat/long so we won’t know where u are
            T 1 Reply Last reply
            • T
              TheSij @sdetweil
              @sdetweil. Thanks, Sam. That’s helpful to explain the general rules.
              I’ve made a slight amendment - I figured that the timezone parameters was not correctly entered (see below - this time just showing the modules before and after). To answer your last point, I did remove the lat/lon values to hide my exact location (this time I’ve put in made-up numbers). With the slight amendment to the code, it’s still not working - do you think it’s the ‘timezone’ value that is causing the problem? I’ve not made any changes to the other modules.
              				appid: "1ab234c567defgh89012ij34k56l78mn"
              			module: 'MMM-PrayerTime',
              			position: 'top_left',	// This can be any of the regions. Best result is in the top_left/top_right.
              				apiVersion: '1.0', // please, leave unchanged. reserved for future use.
              				lat: 12.3456789, // latitude of your position (city)
              				lon: -0.1234567, // longitude of your position (city)
              				timezone: date_default_timezone_set('Europe/London'), // please refer to http://php.net/manual/en/timezones.php
              				timeFormat: 24,
              				method: 5,
              				playAdzan: ['fajr', 'dhuhr', 'asr', 'maghrib', 'isha'],
              				notDisplayed: ['midnight', 'sunset'],
              				showTomorrow: true,
              				alertTimer: 15000
              			module: "newsfeed",
              				feeds: [
              						title: "Reddit",
              						title: "Buzzfeed",
                sdetweil @TheSij
                @TheSij yes, still timezone., that syntax says call a function named date_default_timezone_set
                but I don’t know where that would be.
                just comment out that one line. add // at the start of the line
                • T
                  TheSij @sdetweil
                  @sdetweil - thanks! Unfortunately, still no luck on adding // at the start of the line, or after ‘timezone:’. According to the module creator, the timezone is a required field. I went to the php website that the module creator refers to, but it just doesn’t make sense to me - the coding information on that website is vast and much too advanced for me. I may have to abandon my desire to add this particular module. :-(
                  • Mykle1M
                    @TheSij said in How to add modules. For absolute beginners.:
                    Don’t give up! I just installed this to test it for you. I can see why it was confusing for you but it does work. Here is my config entry. Use it as a template for yours, replacing your info for mine. The following screenshot shows it working.
                    		position: 'top_center',	// This can be any of the regions. Best result is in the top_left/top_right.
                    			lat: myLat, // latitude of your position (city)
                    			lon: myLong, // longitude of your position (city)
                    			timezone: 'Europe/London', // please refer to http://php.net/manual/en/timezones.php
                    //			timeFormat: 24,
                    			method: 5,
                    	//		language: config.language,
                    			showTomorrow: true,
                    			alertTimer: 15000
                    S T 2 Replies Last reply
                      sdetweil @Mykle1
                      @Mykle1 thx!
                      so the original problem was the timezone wasn’t quoted.
                      Mykle1M 1 Reply Last reply
                      • Mykle1M
                        @sdetweil said in How to add modules. For absolute beginners.:
                        That and language: config.language, was causing an error. I simply commented it out and the module uses the config language by default. :-)
                        Edit: Oh, and timeFormat: 24, in the module’s config entry, as well. Again, I commented it out as it was redundant.
                          sdetweil @Mykle1
                          @Mykle1 yep, didn’t see that right… because the javascript source code processor is in the process of reading the config object definition
                          var config= {
                          the config object is not yet defined. so config.language cannot exist (yet)
                          but the timeFormat can be present AND redundant and not cause a startup error
                          • T
                            TheSij @Mykle1
                            @Mykle1 thanks to you and @sdetweil for helping me with this. It’s much appreciated. Deep down I’m reluctant to give up, because I don’t like quitting. I’ve literally just copied your config entry, and simply adding my own lat/lon figures. But now the MagicMirror shows up as a blank black screen and the window is named ‘Electron’, rather than ‘MagicMirror2’.
                            I’m checking, double-checking and triple-checking and I can’t see where the discrepancy is compared to your entry. Could having too many modules be an issue? Can I also check - both of you have commented that the ‘timezone’ is causing an error, but your config entry doesn’t show that it’s commented out…?
                              sdetweil @TheSij
                              @TheSij how do you start MM? npm start, or pm2 start ?
                              if npm start, look at the messages shown in the terminal window after the npm start, or better yet, redirect the messages to a file, so you can look at them later
                              npm start >somefile 2>&1
                              (same as on windows)
                              if pm2, then pm2 logs --lines=100 should display the messages…
                              black screen,m typically means some library required by a module is not loaded, usually because of a missed install step for the module…
                              the area u read on github, is the same as the file README.md after the git clone, so you can look at the instructions
                              git clone
                              cd modulename
                              npm install
                              • T
                                TheSij @sdetweil
                                @sdetweil - this is the log when I started MM just now…
                                1 verbose cli [ '/usr/bin/node', '/usr/local/bin/npm', 'start' ]
                                2 info using npm@6.14.7
                                3 info using node@v10.19.0
                                4 verbose stack Error: missing script: start
                                4 verbose stack     at run (/usr/local/lib/node_modules/npm/lib/run-script.js:155:19)
                                4 verbose stack     at /usr/local/lib/node_modules/npm/lib/run-script.js:63:5
                                4 verbose stack     at /usr/local/lib/node_modules/npm/node_modules/read-package-json/read-json.js:116:5
                                4 verbose stack     at /usr/local/lib/node_modules/npm/node_modules/read-package-json/read-json.js:436:5
                                4 verbose stack     at checkBinReferences_ (/usr/local/lib/node_modules/npm/node_modules/read-package-json/read-json.js:391:45)
                                4 verbose stack     at final (/usr/local/lib/node_modules/npm/node_modules/read-package-json/read-json.js:434:3)
                                4 verbose stack     at then (/usr/local/lib/node_modules/npm/node_modules/read-package-json/read-json.js:161:5)
                                4 verbose stack     at /usr/local/lib/node_modules/npm/node_modules/read-package-json/read-json.js:382:12
                                4 verbose stack     at /usr/local/lib/node_modules/npm/node_modules/graceful-fs/graceful-fs.js:123:16
                                4 verbose stack     at FSReqWrap.readFileAfterClose [as oncomplete] (internal/fs/read_file_context.js:53:3)
                                5 verbose cwd /home/pi/MagicMirror/modules/MMM-soccer
                                6 verbose Linux 4.19.118-v7l+
                                7 verbose argv "/usr/bin/node" "/usr/local/bin/npm" "start"
                                8 verbose node v10.19.0
                                9 verbose npm  v6.14.7
                                10 error missing script: start
                                11 verbose exit [ 1, true ]
                                  sdetweil @TheSij
                                  what did you type?
                                  the command is
                                  npm start
                                  to run MM, you must start from the MagicMirror folder… not a module folder, not the users home folder…
                                  if you use pm2, it will issue the right commands from the right place
                                  • T
                                    TheSij @sdetweil
                                    @sdetweil - apologies, I was in the wrong directory. This is the terminal response…
                                    > magicmirror@2.12.0 start /home/pi/MagicMirror
                                    [2020-07-27 22:56:11.226] [LOG]    Starting MagicMirror: v2.12.0
                                    [2020-07-27 22:56:11.233] [LOG]    Loading config ...
                                    [2020-07-27 22:56:11.238] [LOG]    Loading module helpers ...
                                    [2020-07-27 22:56:11.240] [LOG]    No helper found for module: alert.
                                    [2020-07-27 22:56:11.290] [LOG]    Initializing new module helper ...
                                    [2020-07-27 22:56:11.291] [LOG]    Module helper loaded: updatenotification
                                    [2020-07-27 22:56:11.291] [LOG]    No helper found for module: clock.
                                    [2020-07-27 22:56:11.643] [LOG]    Initializing new module helper ...
                                    [2020-07-27 22:56:11.644] [LOG]    Module helper loaded: calendar
                                    [2020-07-27 22:56:11.645] [LOG]    No helper found for module: currentweather.
                                    [2020-07-27 22:56:11.646] [LOG]    No helper found for module: weatherforecast.
                                    [2020-07-27 22:56:11.678] [LOG]    Initializing new module helper ...
                                    [2020-07-27 22:56:11.678] [LOG]    Module helper loaded: newsfeed
                                    [2020-07-27 22:56:11.679] [LOG]    No helper found for module: MMM-TFL.
                                    [2020-07-27 22:56:11.681] [ERROR]  WARNING! Could not load config file. Starting with default configuration. Error found: Error: Cannot find module 'async'
                                    Require stack:
                                    - /home/pi/MagicMirror/modules/MMM-PrayerTime/node_helper.js
                                    [2020-07-27 22:56:11.682] [LOG]    Loading module helpers ...
                                    [2020-07-27 22:56:11.683] [LOG]    No helper found for module: alert.
                                    [2020-07-27 22:56:11.683] [LOG]    Initializing new module helper ...
                                    [2020-07-27 22:56:11.684] [LOG]    Module helper loaded: updatenotification
                                    [2020-07-27 22:56:11.684] [LOG]    No helper found for module: clock.
                                    [2020-07-27 22:56:11.685] [LOG]    Initializing new module helper ...
                                    [2020-07-27 22:56:11.685] [LOG]    Module helper loaded: calendar
                                    [2020-07-27 22:56:11.685] [LOG]    No helper found for module: currentweather.
                                    [2020-07-27 22:56:11.686] [LOG]    No helper found for module: weatherforecast.
                                    [2020-07-27 22:56:11.686] [LOG]    Initializing new module helper ...
                                    [2020-07-27 22:56:11.686] [LOG]    Module helper loaded: newsfeed
                                    [2020-07-27 22:56:11.687] [LOG]    No helper found for module: MMM-TFL.
                                    [2020-07-27 22:56:11.688] [ERROR]  App threw an error during load
                                    [2020-07-27 22:56:11.689] [ERROR]  Error: Cannot find module 'async'
                                    Require stack:
                                        at Module._resolveFilename (internal/modules/cjs/loader.js:627:15)
                                        at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/common/reset-search-paths.js:41:16)
                                        at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/module-alias/index.js:49:29)
                                        at Function.Module._load (internal/modules/cjs/loader.js:531:27)
                                        at Module.require (internal/modules/cjs/loader.js:685:19)
                                        at require (internal/modules/cjs/helpers.js:16:16)
                                        at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-PrayerTime/node_helper.js:9:13)
                                        at Module._compile (internal/modules/cjs/loader.js:786:30)
                                        at Object.Module._extensions..js (internal/modules/cjs/loader.js:798:10)
                                        at Module.load (internal/modules/cjs/loader.js:645:32)
                                    [2020-07-27 22:56:11.690] [ERROR]  Whoops! There was an uncaught exception...
                                    [2020-07-27 22:56:11.690] [ERROR]  Error: Cannot find module 'async'
                                    Require stack:
                                        at Module.load (internal/modules/cjs/loader.js:645:32) {
                                      code: 'MODULE_NOT_FOUND',
                                      requireStack: [
                                        '/home/pi/MagicMirror/modules/MMM-PrayerTime/node_helper.js',
                                        '/home/pi/MagicMirror/js/app.js',
                                        '/home/pi/MagicMirror/js/electron.js',
                                        '/home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js',
                                        undefined
                                    [2020-07-27 22:56:11.696] [ERROR]  MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                                    [2020-07-27 22:56:11.697] [ERROR]  If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                                    [2020-07-27 22:56:11.814] [LOG]    Launching application.
                                      sdetweil @TheSij
                                      [2020-07-27 22:56:11.690] [ERROR] Error: Cannot find module ‘async’
                                      i suspect you did not do the required install in the
                                      MagicMirror/modules/MMM-PrayerTime folder
                                      per the instructions
                                      Installation
                                      Navigate into your MagicMirror's modules folder
                                      execute git clone https://github.com/slametps/MMM-PrayerTime.git
                                      **if this module does not run correctly,** try npm install async
                                      T S Mykle1M 3 Replies Last reply
                                      • T
                                        TheSij @sdetweil
                                        I am 110% sure I installed the module in the right directory. I always check before I execute it. I’ve just checked the directory, and the module repository is in the right place. I’m executing the ‘npm install async’ command now. Fingers crossed!
                                          sdetweil @TheSij
                                          what does that mean?
                                            I opened an issue on the MMM-PrayerTime module github, for him to create a package.json file for this async dependency and let the system handle it
                                            https://github.com/slametps/MMM-PrayerTime/issues/43
                                            • 2 / 5
