    Calendar with iCloud Cal Problem
    2 Posts 2 Posters 1.5k Views 3 Watching
      SebastianS
      Hi
      i am using an icloud calendar.
      and i was trying to add the URL to the config.js file to calendar.
      and its not working. itsd showing " no upcoming events"
      and there are events …
      what i did, is i went to icloud.com went to calendar and clicked on the share button and went to share and than copied the URL and paste to the config file.
      Its like the sample file. Its also a webcal:// …
      The only difference it does not end with and *ics like the sample.
      but it says al icals are possible and i thought icloud is ical.
      Can someone help me how to get the right URL for my icloud calendar.
      THANKS
      • Y Offline
        Yannik25
        iCloud Calender stopped working for me since last update
        used same option to publish the calender
        and used the link format like https://p57-calendars…
        error log:
        mm-0 (err):     at Request._callback (/home/pi/MagicMirror/modules/default/calendar/vendor/ical.js/node-ical.js:11:5)
        mm-0 (err):     at Request.self.callback (/home/pi/MagicMirror/node_modules/request/request.js:188:22)
        mm-0 (err):     at emitTwo (events.js:106:13)
        mm-0 (err):     at Request.emit (events.js:194:7)
        mm-0 (err):     at Request.<anonymous> (/home/pi/MagicMirror/node_modules/request/request.js:1171:10)
        mm-0 (err): [1627:0814/180246.217060:ERROR:gles2_cmd_decoder_autogen.h(1806)] [.DisplayCompositor-0x4c39480]GL ERROR :GL_INVALID_OPERATION : GetShaderiv: <- error from previous GL command
        mm-0 (err): [1842:0814/183723.973230:ERROR:gles2_cmd_decoder_autogen.h(1806)] [.DisplayCompositor-0x412c480]GL ERROR :GL_INVALID_OPERATION : GetShaderiv: <- error from previous GL command
        mm-0 (err): [1842:0814/183725.964007:ERROR:gles2_cmd_decoder_autogen.h(1806)] [.DisplayCompositor-0x412c480]GL ERROR :GL_INVALID_OPERATION : GetShaderiv: <- error from previous GL command
        mm-0 (err): Error: dates lower than Thu Jan 01 1970 00:00:00 GMT+0100 (CET) are not supported
        mm-0 (err):     at Object.toOrdinal (/home/pi/MagicMirror/node_modules/rrule-alt/lib/rrule.js:105:15)
        mm-0 (err):     at Iterinfo.rebuild (/home/pi/MagicMirror/node_modules/rrule-alt/lib/rrule.js:1409:35)
        mm-0 (err):     at RRule._iter (/home/pi/MagicMirror/node_modules/rrule-alt/lib/rrule.js:978:10)
        mm-0 (err):     at RRule.between (/home/pi/MagicMirror/node_modules/rrule-alt/lib/rrule.js:794:21)
        mm-0 (err):     at /home/pi/MagicMirror/modules/default/calendar/calendarfetcher.js:135:24
        mm-0 (err): [1842:0814/183727.861692:ERROR:gles2_cmd_decoder_autogen.h(1806)] [.DisplayCompositor-0x412c480]GL ERROR :GL_INVALID_OPERATION : GetShaderiv: <- error from previous GL command
