Mirror installation failing
npm start failing on raspberry pi
node -v
v6.9.1 -
info it worked if it ends with ok
1 verbose cli [ ‘/opt/nodejs/bin/node’, ‘/usr/local/bin/npm’, ‘start’ ]
2 info using npm@3.10.8
3 info using node@v6.9.1
4 verbose run-script [ ‘prestart’, ‘start’, ‘poststart’ ]
5 info lifecycle magicmirror@2.1.2~prestart: magicmirror@2.1.2
6 silly lifecycle magicmirror@2.1.2~prestart: no script for prestart, continuing
7 info lifecycle magicmirror@2.1.2~start: magicmirror@2.1.2
8 verbose lifecycle magicmirror@2.1.2~start: unsafe-perm in lifecycle true
9 verbose lifecycle magicmirror@2.1.2~start: PATH: /opt/nodejs/lib/node_modules/npm/bin/node-gyp-bin:/home/pi/MagicMirror/node_modules/.bin:/opt/nodejs/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/b$
10 verbose lifecycle magicmirror@2.1.2~start: CWD: /home/pi/MagicMirror
11 silly lifecycle magicmirror@2.1.2~start: Args: [ ‘-c’, ‘sh run-start.sh’ ]
12 silly lifecycle magicmirror@2.1.2~start: Returned: code: 1 signal: null
13 info lifecycle magicmirror@2.1.2~start: Failed to exec start script
14 verbose stack Error: magicmirror@2.1.2 start:sh run-start.sh
14 verbose stack Exit status 1
14 verbose stack at EventEmitter. (/opt/nodejs/lib/node_modules/npm/lib/utils/lifecycle.js:255:16)
14 verbose stack at emitTwo (events.js:106:13)
14 verbose stack at EventEmitter.emit (events.js:191:7)
14 verbose stack at ChildProcess. (/opt/nodejs/lib/node_modules/npm/lib/utils/spawn.js:40:14)
14 verbose stack at ChildProcess.emit (events.js:191:7)
14 verbose stack at maybeClose (internal/child_process.js:877:16)
14 verbose stack at Process.ChildProcess._handle.onexit (internal/child_process.js:226:5)
15 verbose pkgid magicmirror@2.1.2
16 verbose cwd /home/pi/MagicMirror
17 error Linux 4.4.50-v7+
18 error argv “/opt/nodejs/bin/node” “/usr/local/bin/npm” “start”
19 error node v6.9.1
20 error npm v3.10.8
21 error code ELIFECYCLE
22 error magicmirror@2.1.2 start:sh run-start.sh
22 error Exit status 1
23 error Failed at the magicmirror@2.1.2 start script ‘sh run-start.sh’.@sharmmoh1983 said in Mirror installation failing:
node -v
v6.9.1
