    Access MagicMirror with HTTP?
    14 Posts 4 Posters 15.8k Views 4 Watching
      shashank
      hi, Try to include your local IP subnet in the config file
      var config = {
      port: 8080,
      ipWhitelist: [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”, “::ffff:192.168.0.1/24”, “192.168.0.1/24”],
      P 2 Replies Last reply Reply Quote 0
      • P Offline
        psteimann @shashank
        @shashank
        OK, it works from my internal network now, just had to change the values to 192.168.1.1./24, thanks for this.
        Before, I tried IpWhitelist: [ ], as documented, but then MM2 was showing a black screen only.
        What I want to do is now to make it accessible from out of my place, so I did a port-forwarding in the router with a dns-service to the pi. But this does not work, same error like before at the local network. Current IP starts with 85… Can I add another entry or just edit one of the 192. value and if yes, which one?
        Thanks!
        Peter
        • P Offline
          psteimann @shashank
          @shashank
          I started MM2 with the console now:-) Thanks Mikle1.
          It works in the local network now as I wrote in the posting above. But I get an issue-report. Is this important?
          Whoops! There was an uncaught exception…
          { Error: listen EADDRINUSE :::8088
          at Object.exports._errnoException (util.js:1050:11)
          at exports._exceptionWithHostPort (util.js:1073:20)
          at Server.setupListenHandle [as _listen2] (net.js:1263:14)
          at listenInCluster (net.js:1304:12)
          at Server.listen (net.js:1402:7)
          at new Server (/home/pi/MagicMirror/js/server.js:26:9)
          at /home/pi/MagicMirror/js/app.js:219:18
          at loadNextModule (/home/pi/MagicMirror/js/app.js:168:5)
          at /home/pi/MagicMirror/js/app.js:163:6
          at Class.loaded (/home/pi/MagicMirror/modules/node_modules/node_helper/index.js:19:3)
          code: ‘EADDRINUSE’,
          errno: ‘EADDRINUSE’,
          syscall: ‘listen’,
          address: ‘::’,
          port: 8088 }
          Launching application.
          Greez Peter
          • ? Offline
            A Former User @psteimann
            @psteimann you are already using port 8088, is there any program which is using that port? Or you executed mm twice at same time. Common pitfall is not killing pm2 and starting another npm (or node serveronly) for test…
            • P Offline
              psteimann @Guest
              @Sean Port 8088 is not used by another program and there Is no other port-forwarding to this port.
              8080 is used by my NAS, so I changed the standard-port to 8088 in the config.js
              i start mm2 automatically with pm2, thats correct. but I do not start it twice.
              do you mean to try to start another instance of mm2 with npm start?
              Thanks!
              • ? Offline
                @psteimann sorry for my poor English. You SHOUD NOT execute twice, before killing pm2.
                • P Offline
                  psteimann @Guest
                  @Sean So you mean I shall kill pm2 and start with npm?
                  how do I kill the pm2-process? If I try to close the pm2-window, it starts again immediately… in the console I guess, but whats the syntax?
                  • ? Offline
                    @psteimann pm2 stop mm
                    • P Offline
                      psteimann
                      Ok, that worked so far. stopped mm2 and startet it manually with npm in the console.
                      Errors have gone, great. So is it an issue with pm2?
                      Unfortunately, still no access from outside.
                      link:
                      timesoft.internet-box.ch:8088
                      • P Offline
                        psteimann @Guest
                        @Sean
                        OK. it works now
                        I entered a second whitelist entry for the external ip:
                        ip is currently:
                        178.198.19.38
                        so i added ffff:178.198.19.1/24…
                        thanks for help
