    After update, Calendar shows infinite number of events.
    16 Posts 6 Posters 9.5k Views 6 Watching
    • G Offline
      gripworks
      Ok so not really infinite, but in the settings I have it set to show the next 15 events. However after the most recent update the number of events continues off the bottom of the screen. This pushes the month calendar off the bottom and runs behind the headlines. Any help would be appreciated.
      • K Offline
        kvicksson
        I have this problem too! Someone who has a suggestion on how to solve this problem?
        • G Offline
          gripworks @kvicksson
          @kvicksson
          I saw in another thread that it is showing the number of posts specified in the config, but on a per calendar basis. I wanted to show 15 events total, but with 8 calendars it is trying to show 120 events. I went into the config file and changed it to 4 events and now it is showing 32 total. More than I had originally but still small enough that it fits on my mirror. Hopefully an update will return it to a configured Total.
          • K Offline
            kvicksson @gripworks
            @gripworks I’ve already tried this and unfortunately it didn’t work for me with two calendars :(
            • O Offline
              orayoflighto Project Sponsor @kvicksson
              @kvicksson
              Did you put maximumEntries after each URL call like below?
              url: ‘https://google.com/public/basic.ics’,
              maximumEntries: ‘10’,
              • G Offline
                gripworks @orayoflighto
                @orayoflighto
                No I didn’t. When I set it up last year, I must have missed that. I’ll give it a try. Thank you.
                • O Offline
                  You didn’t miss it. It is a change with the most recent update.
                  slametpsS 1 Reply Last reply Reply Quote 0
                  • slametpsS Offline
                    slametps @orayoflighto
                    @orayoflighto said in After update, Calendar shows infinite number of events.:
                    Default value for maximumEntries is 10. How can the calendar module display infinite number of events because not setting maximumEntries option?
                    regards,
                    Slamet PS
                    O G 2 Replies Last reply Reply Quote 0
                    • O Offline
                      orayoflighto Project Sponsor @slametps
                      @slametps
                      The maximumEntries setting now applies to each calendar rather than globally. So if you have 5 calendar URLs then you get 50 listings (if the default is set to 10). Before the change it would show the most recent 10 events from all of your calendars.
                      • K Offline
                        kvicksson
                        Everything works after setting maximumEntries after each URL. I don’t like it though because it doesn’t show the 10 upcoming items due to where the items are in time. But guess I have to live with it :)
                          jasondreher
                          Is there any way to go back a version or install a prior version? I have the same calendar issue. The installation mentions git reset --hard, but I am not sure what that does.
                          G Mykle1M 2 Replies Last reply Reply Quote 0
                          • G Offline
                            gripworks @slametps
                            @slametps
                            It wasn’t truly infinite, I just have 8 Calendars so with 80 lines to display (the default 10/calendar) it ran off the bottom of the screen, behind the headlines and pushing the monthly calendar off the screen.
                            • G Offline
                              gripworks @jasondreher
                              @jasondreher Like kvicksson posted earlier in this thread
                              You can now setup on a per calendar basis, which I really like. I think it is a great imporvement.
                              • slametpsS Offline
                                slametps @kvicksson
                                @kvicksson said in After update, Calendar shows infinite number of events.:
                                IMHO, It will be better if there is still a global config limiting total closest event will be displayed.
                                regards,
                                Slamet PS
                                  Mykle1 Project Sponsor Module Developer @jasondreher
                                  @jasondreher said in After update, Calendar shows infinite number of events.:
                                  https://github.com/MichMich/MagicMirror/releases
                                  Move or rename your current MagicMirror folder and you won’t lose anything
                                    jasondreher @Mykle1
                                    @Mykle1
                                    Thanks, I was looking there, but now I see the “Source code (zip)” link! I just replaced the calendar module and now it is back to the way I want it.
