    MMM-Wunderlist-Enhanced javascript error
    14 Posts 2 Posters 5.5k Views 2 Watching
    • G Offline
      geeklimit
      I’d love to use Chromium instead of Midori, but the tutorial I followed for getting MagicMirror working on a Pi Zero W used Midori, and I don’t know a lot about what I’m doing.
      Theoretically I could look up how to install Chromium and change the browser-boot script from:
      #!/bin/sh
      unclutter &
      xset -dpms # disable DPMS (Energy Star) features.
      xset s off # disable screen saver
      xset s noblank # don’t blank the video device
      matchbox-window-manager &
      midori -e Fullscreen -a http://localhost:8080
      to
      #!/bin/sh
      unclutter &
      chromium-browser --no-sandbox --app="http://localhost:8080"
      Assuming that Chromium uses the same switches?
      Installing Chromium now via:
      sudo apt-get -y install chromium-browser
      Will test.
      • ? Offline
        A Former User @geeklimit
          getTodos: function() {
            var tasks = [];
              var self = this;
            this.config.lists.forEach( function (listValue, listKey) {
              let list = self.tasks[listValue];
              if (list && list.length)
                list.forEach(function (todo)  {
                  if (self.config.order === 'reversed') {
                    tasks.push(todo);
                  } else {
                    tasks.unshift(todo)
        This ie rewritten code (not tested but I think it will work.)
        • G Offline
          geeklimit
          Thanks! I am having other “SyntaxError: Unexpected token” errors in other modules as well, as you guessed.
          Trying chromium first. I think that might be a better option, because even the default Compliments.js module has the same error.
          • G Offline
            geeklimit
            OK, that fixed all of the modules I was having trouble with, but getting Chromium to work right wasn’t easy.
            Chromium doesn’t like to be run as root (via startup script) you have to give it the flag:
            --no-sandbox
            Which doesn’t work, so instead you need to do this to run it as pi:
            su pi -c 'chromium-browser --kiosk --noerrdialogs http://localhost:8080
            To launch it without toolbars or a window (fullscreen), you have to give it the flag:
            --kiosk
            I tried the -app switch, and it removes the toolbars but leaves the window, so --kiosk is the way to go.
            But this leaves an annoying warning about --no-sandbox not being supported, so you have to also add in:
            --noerrdialogs
            Chromium also does an annoying popup when the Pi is rebooted without properly closing Chromium: “Chromium was not shut down correctly”. (power cycle or sudo reboot in the terminal). So you can try to edit Chromium’s file before it launches to make it think it shut down OK:
            sed -i 's/"exited_cleanly": false/"exited_cleanly": true/' ~/.config/chromium/Default/Preferences
            Which doesn’t work because ~/ doesn’t work as expected when it’s a root-run startup script looking for a path in /home/pi/, so:
            sed -i 's/"exited_cleanly": false/"exited_cleanly": true/' /home/pi/.config/chromium/Default/Preferences
            Which didn’t work either, so I tried using some older documentation:
            su pi -c 'chromium-browser --start-fullscreen --disable-session-crashed-bubble --disable-infobars http://localhost:8080
            Which also didn’t work.
            So… Then I realized I don’t really care about my browsing session data at all, so tried this:
            su pi -c 'chromium-browser --kiosk --incognito http://localhost:8080
            And that works, every time. Even when the Pi is power cycled.
            Yikes.
            So the complete launch command of “midori-start.sh” (now modified for Chromium) is:
            #!/bin/sh
            unclutter &
            su pi -c 'chromium-browser --kiosk --incognito http://localhost:8080'
            This also gets rid of the balloon telling me that “I can search here with Google”, pointing to where the address bar should be when Pi opens Chrome for the first time. It only happens once, but nice to clear that out as well.
            The moral of the story here is: Don’t try to be fancy, just brute force the f@#$ing thing.
