    pm2 doesn't start after mm update
    18 Posts 4 Posters 10.5k Views 3 Watching
    • K Offline
      kurt @lavolp3
      @lavolp3
      Hi lavolp3
      Bevor the update, pm2 startet the mirror, by now nothing happens at all, even no black screen etc.
      do you know a way to heal the mirror?
        Mykle1 Project Sponsor Module Developer @kurt
        @kurt said in pm2 doesn’t start after mm update:
        To get things right: first thing is to rename the MagicMirror folder.
        Yes, but then I suggest you do a manual installation. If you run the automatic installer script you may run into trouble again.
        Rename your MagicMirror folder. Go to https://github.com/MichMich/MagicMirror and click on the green Clone or download button on the right
        side of the window, then click on Download ZIP. Now you have a MagicMirror-master.zip file. Double Click the file. Inside is the MagicMirror-master folder. Move that file to your /home/pi folder. Rename that folder to MagicMirror. Then in your terminal, cd into the MagicMirror directory and run npm install. When that finishes, run npm start, also in the MagicMirror directory.
        At this point the mirror should run but you’ll likely get a “Create a config” message displayed. At which point you should do this.
        https://forum.magicmirror.builders/topic/4528/how-to-create-a-working-config-for-absolute-beginners
        Then back to your terminal, in the MagicMirror directory, run npm start. That should get your mirror running.
        Then you can copy your modules, 1 by 1 into the new MagicMirror/modules folder and the entries into your new config.js file.
        That should do it.
        • K Offline
          kurt @Mykle1
          @Mykle1
          Hi Mykle1 and Thank you for your help so much!
          After I followed your help step by step the mirror appeared again, but I was suprised when I put all my modul folder into the “new mm”, that together with the old config. file everything worked out fine. Could’t believe that it was that easy.
          But still I have two more things where I could’t get a for me clear solution in the forum:
          DeprecationWarning: sys is deprecated. Use util instead.
          and the second thing is, that I can`t find the Remote control funktion on my mobile phone, as I found it bevor. Here is the part of my config.
          Is there the “0.0.0.0” in ipWhitelist missing, and if yes, where to put it?
          Kurt
          var config =
          	electronOptions: {
          	  ipWhitelist: [
          		"::fff:0.0.0.0/1",
          		"::fff:128.0.0.0/2",
          		"::fff:192.0.0.0/3",
          		"::fff:224.0.0.0/4",
          		"127.0.0.1",
          		"::ffff:127.0.0.1",
          		"::1"
            You got lucky. The step by step says one at a time. I’m just saying. :^)
            Probably, one of the modules you are using has a dependency that is outdated or no longer supported. It has nothing to do with the MM software. You can ignore that warning.
            This has been discussed lately on the forum. Do a search by clicking the little magnifying glass, top right of the forum window. If you can’t find an answer, come back here and tell me.
            K 1 Reply Last reply Reply Quote 1
            • K Offline
              kurt @Mykle1
              @Mykle1
              I tried several changes to my ipWhitelist after I read the posts in https://forum.magicmirror.builders/topic/5015/after-update-to-mirror-to-2-1-3-no-working-whitlist
              but I couldn’t get it right. So I hope you can.
              Thank you in advance
              Kurt
                That’s a lot of pressure. :^)
                Try this at the very beginning of your config.js file, so it looks like this:
                var config = {
                	port: 8080,
                        address: "0.0.0.0",
                	ipWhitelist: [], // Set [] to allow all IP addresses.
                K 1 Reply Last reply Reply Quote 2
                • K Offline
                  kurt @Mykle1
                  @Mykle1
                  Sorry for feeling presure, but you made it again! Works like a charm!
                  Once again Thank you!
                  Kurt
                    No worries mate. I’m glad you’re up and running again!
