Adding Google Calendar in MMM
@Sean :-/ it’s stuck with “Loading…”
@hoofta
How is your internet condition? Your mirror is connected to internet? -
@Sean typically strong - fiber with at least 500gb up/down. (typing on laptop now). Internet seems very slow on r.pi running MMM. Any suggestions to boost internet speed?
@hoofta
no, just checking things clearly.
And let’s check more things;- How’s other modules? e.g) clock, news feed, or any other third parties… Only calendar module has the problem?
- Default sample “US-Holiday” was shown normally?
- Have you tried
npm run config:check? what was the result? - Have you tried
npm start dev? what was the result?
@hoofta said in Adding Google Calendar in MMM:
I’d missed this. if so, that might be the reason. But I have no idea to speed up your internet connections.
@Sean
r.pi speedtest.net returns .1 down speed
I have not been able to get any other third party modules going. I have attempted the MMM-MyCommute and an iframe module for a NestCam. Neither have worked - only broke MMM.
no syntax error from config:check
npm start dev loaded MMM normally with dev script on the right.
only possible red flag is that I see for calendar is in text/javascript there is a double “/” between calendars -
@hoofta I’ll play the newbie card on this one and admit I just found an extra “s” at the end of basic, which was causing my issue.
Can I add multiple calendars to the same area so chronologically they play nicely together?
@hoofta nice for you. It will work and ask again.
