    MMM-RTSPStream dosent work in my case
    15 Posts 4 Posters 9.6k Views 3 Watching
      alverman
      good night
      It’s all day that I try to run the MMM-RTSPStream module without results.
      My cameras are connected to a dvr and the stream I need to view takes it from the dvr with this string:
      rtsp: //10.0.0.60: 554/h264/?ch=1&subtype=1&authbasic=admin:123456
      Using vlc on a regular pc all works at the first shot.
      Using ffplay on a regular pc works
      If I use ffplay on raspberry, outside mmm, it works but after about a minute the flow stops.
      If I use the form in magicmirror I see a window without stream.
      My configuration in config.js is:
      module: "MMM-RTSPStream",
      position: "slide1mods_bottom_left",
      header: "Video Surveillance",
      autoStart: true,
      rotateStreams: true,
      rotateStreamTimeout: 10,
      moduleWidth: 3,
      moduleHeight: 240,
      localPlayer: "omxplayer",
      remotePlayer: "ffmpeg",
      showSnapWhenPaused: true,
      remoteSnaps: true,
      stream1: {
      url: "rtsp: //10.0.0.60: 554 / h264 /? ch = 1 & subtype = 1 & authbasic = admin: 123456"
      frameRate: '15',
      protocol: 'tcp',
      hdUrl: 'none',
      snapshotType: 'url',
      snapshotRefresh: 10,
      width: undefined,
      height: undefined,
      ffmpegPort: 9999,
      When magicmirror runs, I see:
      Create new news fetcher for url: http://www.repubblica.it/rss/cronaca/rss2.0.xml - Interval: 300000
      Starting WebSocket server on port 9999. Waiting for connections …
      Starting stream stream1 with args: [
          “–avdict”
          “Rtsp_transport: tcp”
          “–win”
          “139, 1546, 491, 1788”
          “–live”
          “–video_queue”
          “4”
          “–fps”
          “30”,
          “Rtsp: //10.0.0.60: 554 / h264 /? Ch = 1 & subtype = 1 & authbasic = admin: 123456”
      Starting PM2 for omx_stream1
      PM2 started for omx_stream1
      It looks okay but I do not see the stream
      If I run console omxplayer I see:
      pi $ pi3mmm: ~ / MagicMirror $ omxplayer “rtsp: //10.0.0.60: 554 / h264 /? ch = 1 & subtype = 1 & authbasic = admin: 123456”
      Video codec omx-h264 width 320 height 240 profile 77 fps 15.000000
      Audio codec pcm_alaw channels 1 samplerate 8000 bitspersample 8
      Subtitle count: 0, state: off, index: 1, delay: 0
      V: PortSettingsChanged: 320x240@15.00 interlace: 0 deinterlace: 0 anaglyph: 0 par: 1.00 display: 0 layer: 0 alpha: 255 aspectMode: 0
      and I can not see any streams open
      If I run ffplay from console I see:
      Input # 0, rtsp, from ‘rtsp: //10.0.0.60: 554 / h264 /? Ch = 1 & subtype = 1 & authbasic = admin: 123456’:
        Metadata:
          title: ZNRTSPServer
        Duration: N / A, start: 2.133311, bitrate: N / A
          Stream # 0: 0: Video: h264 (Main), yuv420p (tv, bt709, progressive), 320x240, 15 fps, 15 tbr, 90k tbn, 30 tbc
          Stream # 0: 1: Audio: pcm_alaw, 8000 Hz, 1 channel, s16, 64 kb / s
      you open a window where I see the stream but after about a minute it locks.
      Help, advice?
      Thank you, Alberto
        barnosch
        did you put some spaces between the URL for better reading in the forum, or could this be the issue?
        Should be look like this imho
        url: "rtsp://10.0.0.60:554/h264/?ch=1&subtype=1&authbasic=admin:123456"
        Have you tried to stream the teststream from the example?
        Just to see if everything is set up correctly from module side.
          alverman
          hi barnosch,
          the string is just that inserted in the forum has taken this look.
          The string in the configuration is right.
          One test I did not do is the one you have proposed.
          after I put the video file on my desktop I changed the form string with:
          autoStart: true,
          moduleWidth: 3,
          moduleHeight: 240,
          remoteSnaps: true,
          stream1: {
          // url: "rtsp://10.0.0.60:554/h264/?ch=1&subtype=1&authbasic=admin:123456"
          url: '/home/pi/Desktop/test.h264',
          frameRate: '15',
          protocol: 'tcp',
          hdUrl: 'none',
          width: undefined,
          height: undefined,
          ffmpegPort: 9999,
          But you see nothing.
          Performing the console test file with:
          omxplayer /home/pi/Desktop/test.h264
          I see the movie !!
          I do not know what else to try !!
            barnosch
            have you installed the dependencies from the module?
            “npm install” within the MMM-RTSP folder
            Could it maybe be a issue with your custom made CSS “postition”?
            Maybe you should try a ordinary original one for testing
              alverman
              Hi barnosch,
              I ran npm install in the module MMM-RTSPStram folder.
              I had already tried the normal MagicMirror css and went the same way.
              On pi3 I have two versions of MagicMirror installed.
              An original and one with all the modules I need.
              To try one or the other version, rename the Home/pi/MagicMirror folder and test it
              Thanks for your attenction, Alberto
                alverman
                Good morning,
                I made a small step but I have not been able to solve it yet.
                Until now I have tried console to display rtsp stream from my dvr without result.
                Just putting the line -n -1 (no audio) succeeded, from the command line, to display the flow.
                Then in the configuration file (config.js) or the MMM-RTSTStream module you should enter the parsing -n -1 !!
                But how do I do it?
                Thank you, Alberto
                  alverman
                  Another problem, always in console, is that if the stream tends to lower itself, the omxplayer closes
                    alverman
                    So I think I’ve solved the problem of why the console flow is interrupted!
                    from console I have to give this command:
                    omxplayer -g -n -1 --timeout 0 --avdict rtsp_transport: tcp "rtsp://10.0.0.60:554/h264/?ch=1&subtype=1& authbasic = admin:123456"
                    So now how can I add the switches:
                    -g -1 --timeout 0 --avdict rtsp_transport: tcp
                    in config.js?
                    Any help please?
                    Thank you, Alberto
                      alverman
                      @alverman said in MMM-RTSPStream dosent work in my case:
                      omxplayer -n -1 --timeout 0 --avdict rtsp_transport: tcp “rtsp://10.0.0.60:554/h264/?ch=1&subtype=1& authbasic = admin:123456”
                      in config.js?
                      Any help please?
                      Thank you, Alberto
                        alverman
                        Sorry if I keep on this monologue but I’m going crazy !!
                        I’ve tried MagicMirror with only the standard modules and the MMM-RSPSream module.
                        Created the code to enter in config.js
                        Enter the code in config.js
                        Starting npm start I see the frame of rtsp stream but I do not see anything.
                        If I hit the frame I see the play icon if I get it I see the pause icon as if the stream was played but I see nothing.
                        I’m really tired of this thing.
                        I know it might go but it does not go and I just miss this form to close the project.
                        Really give me a hand please
                        Thank you, Alberto
