    MMM-RTSPStream dosent work in my case
    15 Posts 4 Posters 10.4k Views 3 Watching
      barnosch
      Here is my working config.
                      module: 'MMM-RTSPStream',
                      position: 'bottom_left',
                              autoStart: true,
                              rotateStreams: false,
                              rotateStreamTimeout: 10,
                              showSnapWhenPaused: false,
                              moduleWidth: 352,
                              moduleHeight: 240,
                              moduleOffset: -20,
                              localPlayer: 'omxplayer',  //omxplayer oder ffmpeg
                      stream1: {
                              url: 'rtsp://10.30.10.28', //update with your IP
                              snapshotUrl: '',
                              snapshotRefresh: 10, // Seconds
                              frameRate: "30",
                              port: 9999,
      i would suggest, you only change the IP adress, without port or the authbasic stuff…
      I also have password set, but for some reason, i do not need to pass it to the module.
      I played around a little bit, but as soon as i change the port or something… it does not work anymore.
      Maybe worth a try.
      Otherwise, bring the developer in here… he is very helpful and has for sure another tips you can try.
        alverman
        Thanks barnosch,
        I think I’ve solved the problem: D
        I think because I’m working remotely and I can not see if the stream is shown or not but I trust.
        I practically lost a pass that eliminated the sound.
        So I think that everything is resolved.
        I see the stable connection from the remote console and then almost for sure that the module now works.
        I find it in issue.
        The command it solves is:
        git fetch - all
        git checkout nosound
        I’ll let you know as soon as I see it with my eyes
          alverman
          Solved !!
            shbatm Module Developer
            @alverman – I’m the creator of the module and I wanted to apologize, I’ve been working on other projects and not following this forum very closely the past few months. I’m glad you got everything solved, I’m sorry I wasn’t able to assist.
            In the future, if you have any issues with one of the modules I created, please tag me (@shbatm) or open an issue on the module’s Issue page at github.com so I get a notification and will be happy to assist.
              sepulvar
              Can you share your final configuration?
