    MMM-RTSPStream dosent work in my case
    15 Posts 4 Posters 11.0k Views 3 Watching
      alverman
      hi barnosch,
      the string is just that inserted in the forum has taken this look.
      The string in the configuration is right.
      One test I did not do is the one you have proposed.
      after I put the video file on my desktop I changed the form string with:
      module: "MMM-RTSPStream",
      position: "slide1mods_bottom_left",
      header: "Video Surveillance",
      autoStart: true,
      rotateStreams: true,
      rotateStreamTimeout: 10,
      moduleWidth: 3,
      moduleHeight: 240,
      localPlayer: "omxplayer",
      remotePlayer: "ffmpeg",
      showSnapWhenPaused: true,
      remoteSnaps: true,
      stream1: {
      // url: "rtsp://10.0.0.60:554/h264/?ch=1&subtype=1&authbasic=admin:123456"
      url: '/home/pi/Desktop/test.h264',
      frameRate: '15',
      protocol: 'tcp',
      hdUrl: 'none',
      snapshotType: 'url',
      snapshotRefresh: 10,
      width: undefined,
      height: undefined,
      ffmpegPort: 9999,
      But you see nothing.
      Performing the console test file with:
      omxplayer /home/pi/Desktop/test.h264
      I see the movie !!
      I do not know what else to try !!
        barnosch
        have you installed the dependencies from the module?
        “npm install” within the MMM-RTSP folder
        Could it maybe be a issue with your custom made CSS “postition”?
        Maybe you should try a ordinary original one for testing
          alverman
          Hi barnosch,
          I ran npm install in the module MMM-RTSPStram folder.
          I had already tried the normal MagicMirror css and went the same way.
          On pi3 I have two versions of MagicMirror installed.
          An original and one with all the modules I need.
          To try one or the other version, rename the Home/pi/MagicMirror folder and test it
          Thanks for your attenction, Alberto
            alverman
            Good morning,
            I made a small step but I have not been able to solve it yet.
            Until now I have tried console to display rtsp stream from my dvr without result.
            Just putting the line -n -1 (no audio) succeeded, from the command line, to display the flow.
            Then in the configuration file (config.js) or the MMM-RTSTStream module you should enter the parsing -n -1 !!
            But how do I do it?
            Thank you, Alberto
              alverman
              Another problem, always in console, is that if the stream tends to lower itself, the omxplayer closes
                alverman
                So I think I’ve solved the problem of why the console flow is interrupted!
                from console I have to give this command:
                omxplayer -g -n -1 --timeout 0 --avdict rtsp_transport: tcp "rtsp://10.0.0.60:554/h264/?ch=1&subtype=1& authbasic = admin:123456"
                So now how can I add the switches:
                -g -1 --timeout 0 --avdict rtsp_transport: tcp
                in config.js?
                Any help please?
                Thank you, Alberto
                  alverman
                  @alverman said in MMM-RTSPStream dosent work in my case:
                  omxplayer -n -1 --timeout 0 --avdict rtsp_transport: tcp “rtsp://10.0.0.60:554/h264/?ch=1&subtype=1& authbasic = admin:123456”
                  in config.js?
                  Any help please?
                  Thank you, Alberto
                    alverman
                    Sorry if I keep on this monologue but I’m going crazy !!
                    I’ve tried MagicMirror with only the standard modules and the MMM-RSPSream module.
                    Created the code to enter in config.js
                    Enter the code in config.js
                    Starting npm start I see the frame of rtsp stream but I do not see anything.
                    If I hit the frame I see the play icon if I get it I see the pause icon as if the stream was played but I see nothing.
                    I’m really tired of this thing.
                    I know it might go but it does not go and I just miss this form to close the project.
                    Really give me a hand please
                    Thank you, Alberto
                      barnosch
                      Here is my working config.
                                      module: 'MMM-RTSPStream',
                                      position: 'bottom_left',
                                              autoStart: true,
                                              rotateStreams: false,
                                              showSnapWhenPaused: false,
                                              moduleWidth: 352,
                                              moduleHeight: 240,
                                              moduleOffset: -20,
                                              localPlayer: 'omxplayer',  //omxplayer oder ffmpeg
                                      stream1: {
                                              url: 'rtsp://10.30.10.28', //update with your IP
                                              snapshotUrl: '',
                                              snapshotRefresh: 10, // Seconds
                                              frameRate: "30",
                                              port: 9999,
                      i would suggest, you only change the IP adress, without port or the authbasic stuff…
                      I also have password set, but for some reason, i do not need to pass it to the module.
                      I played around a little bit, but as soon as i change the port or something… it does not work anymore.
                      Maybe worth a try.
                      Otherwise, bring the developer in here… he is very helpful and has for sure another tips you can try.
                        alverman
                        Thanks barnosch,
                        I think I’ve solved the problem: D
                        I think because I’m working remotely and I can not see if the stream is shown or not but I trust.
                        I practically lost a pass that eliminated the sound.
                        So I think that everything is resolved.
                        I see the stable connection from the remote console and then almost for sure that the module now works.
                        I find it in issue.
                        The command it solves is:
                        git fetch - all
                        git checkout nosound
                        I’ll let you know as soon as I see it with my eyes
                          alverman
                          Solved !!
                            shbatm Module Developer
                            @alverman – I’m the creator of the module and I wanted to apologize, I’ve been working on other projects and not following this forum very closely the past few months. I’m glad you got everything solved, I’m sorry I wasn’t able to assist.
                            In the future, if you have any issues with one of the modules I created, please tag me (@shbatm) or open an issue on the module’s Issue page at github.com so I get a notification and will be happy to assist.
                              sepulvar
                              Can you share your final configuration?
