    MMM-RTSPStream dosent work in my case
    15 Posts 4 Posters 11.2k Views 3 Watching
    • A
      alverman
      Hi barnosch,
      I ran npm install in the module MMM-RTSPStram folder.
      I had already tried the normal MagicMirror css and went the same way.
      On pi3 I have two versions of MagicMirror installed.
      An original and one with all the modules I need.
      To try one or the other version, rename the Home/pi/MagicMirror folder and test it
      Thanks for your attenction, Alberto
      • A
        alverman
        Good morning,
        I made a small step but I have not been able to solve it yet.
        Until now I have tried console to display rtsp stream from my dvr without result.
        Just putting the line -n -1 (no audio) succeeded, from the command line, to display the flow.
        Then in the configuration file (config.js) or the MMM-RTSTStream module you should enter the parsing -n -1 !!
        But how do I do it?
        Thank you, Alberto
        • A
          alverman
          Another problem, always in console, is that if the stream tends to lower itself, the omxplayer closes
          • A
            alverman
            So I think I’ve solved the problem of why the console flow is interrupted!
            from console I have to give this command:
            omxplayer -g -n -1 --timeout 0 --avdict rtsp_transport: tcp "rtsp://10.0.0.60:554/h264/?ch=1&subtype=1& authbasic = admin:123456"
            So now how can I add the switches:
            -g -1 --timeout 0 --avdict rtsp_transport: tcp
            in config.js?
            Any help please?
            Thank you, Alberto
            • A
              alverman
              @alverman said in MMM-RTSPStream dosent work in my case:
              omxplayer -n -1 --timeout 0 --avdict rtsp_transport: tcp “rtsp://10.0.0.60:554/h264/?ch=1&subtype=1& authbasic = admin:123456”
              in config.js?
              Any help please?
              Thank you, Alberto
              • A
                alverman
                Sorry if I keep on this monologue but I’m going crazy !!
                I’ve tried MagicMirror with only the standard modules and the MMM-RSPSream module.
                Created the code to enter in config.js
                Enter the code in config.js
                Starting npm start I see the frame of rtsp stream but I do not see anything.
                If I hit the frame I see the play icon if I get it I see the pause icon as if the stream was played but I see nothing.
                I’m really tired of this thing.
                I know it might go but it does not go and I just miss this form to close the project.
                Really give me a hand please
                Thank you, Alberto
                  barnosch
                  Here is my working config.
                                  module: 'MMM-RTSPStream',
                                  position: 'bottom_left',
                                          autoStart: true,
                                          rotateStreams: false,
                                          rotateStreamTimeout: 10,
                                          showSnapWhenPaused: false,
                                          moduleWidth: 352,
                                          moduleHeight: 240,
                                          moduleOffset: -20,
                                          localPlayer: 'omxplayer',  //omxplayer oder ffmpeg
                                  stream1: {
                                          url: 'rtsp://10.30.10.28', //update with your IP
                                          snapshotUrl: '',
                                          snapshotRefresh: 10, // Seconds
                                          frameRate: "30",
                                          port: 9999,
                  i would suggest, you only change the IP adress, without port or the authbasic stuff…
                  I also have password set, but for some reason, i do not need to pass it to the module.
                  I played around a little bit, but as soon as i change the port or something… it does not work anymore.
                  Maybe worth a try.
                  Otherwise, bring the developer in here… he is very helpful and has for sure another tips you can try.
                  • A
                    alverman
                    Thanks barnosch,
                    I think I’ve solved the problem: D
                    I think because I’m working remotely and I can not see if the stream is shown or not but I trust.
                    I practically lost a pass that eliminated the sound.
                    So I think that everything is resolved.
                    I see the stable connection from the remote console and then almost for sure that the module now works.
                    I find it in issue.
                    The command it solves is:
                    git fetch - all
                    git checkout nosound
                    I’ll let you know as soon as I see it with my eyes
                    • A
                      alverman
                      Solved !!
                        shbatm Module Developer
                        @alverman – I’m the creator of the module and I wanted to apologize, I’ve been working on other projects and not following this forum very closely the past few months. I’m glad you got everything solved, I’m sorry I wasn’t able to assist.
                        In the future, if you have any issues with one of the modules I created, please tag me (@shbatm) or open an issue on the module’s Issue page at github.com so I get a notification and will be happy to assist.
                          sepulvar
                          Can you share your final configuration?
