    MMM-RTSPStream dosent work in my case
    15 Posts 4 Posters 11.2k Views 3 Watching
    • A
      alverman
      Good morning,
      I made a small step but I have not been able to solve it yet.
      Until now I have tried console to display rtsp stream from my dvr without result.
      Just putting the line -n -1 (no audio) succeeded, from the command line, to display the flow.
      Then in the configuration file (config.js) or the MMM-RTSTStream module you should enter the parsing -n -1 !!
      But how do I do it?
      Thank you, Alberto
      • A
        alverman
        Another problem, always in console, is that if the stream tends to lower itself, the omxplayer closes
        • A
          alverman
          So I think I’ve solved the problem of why the console flow is interrupted!
          from console I have to give this command:
          omxplayer -g -n -1 --timeout 0 --avdict rtsp_transport: tcp "rtsp://10.0.0.60:554/h264/?ch=1&subtype=1& authbasic = admin:123456"
          So now how can I add the switches:
          -g -1 --timeout 0 --avdict rtsp_transport: tcp
          in config.js?
          Any help please?
          Thank you, Alberto
          • A
            alverman
            @alverman said in MMM-RTSPStream dosent work in my case:
            omxplayer -n -1 --timeout 0 --avdict rtsp_transport: tcp “rtsp://10.0.0.60:554/h264/?ch=1&subtype=1& authbasic = admin:123456”
            in config.js?
            Any help please?
            Thank you, Alberto
            • A
              alverman
              Sorry if I keep on this monologue but I’m going crazy !!
              I’ve tried MagicMirror with only the standard modules and the MMM-RSPSream module.
              Created the code to enter in config.js
              Enter the code in config.js
              Starting npm start I see the frame of rtsp stream but I do not see anything.
              If I hit the frame I see the play icon if I get it I see the pause icon as if the stream was played but I see nothing.
              I’m really tired of this thing.
              I know it might go but it does not go and I just miss this form to close the project.
              Really give me a hand please
              Thank you, Alberto
                barnosch
                Here is my working config.
                                module: 'MMM-RTSPStream',
                                position: 'bottom_left',
                                        autoStart: true,
                                        rotateStreams: false,
                                        rotateStreamTimeout: 10,
                                        showSnapWhenPaused: false,
                                        moduleWidth: 352,
                                        moduleHeight: 240,
                                        moduleOffset: -20,
                                        localPlayer: 'omxplayer',  //omxplayer oder ffmpeg
                                stream1: {
                                        url: 'rtsp://10.30.10.28', //update with your IP
                                        snapshotUrl: '',
                                        snapshotRefresh: 10, // Seconds
                                        frameRate: "30",
                                        port: 9999,
                i would suggest, you only change the IP adress, without port or the authbasic stuff…
                I also have password set, but for some reason, i do not need to pass it to the module.
                I played around a little bit, but as soon as i change the port or something… it does not work anymore.
                Maybe worth a try.
                Otherwise, bring the developer in here… he is very helpful and has for sure another tips you can try.
                • A
                  alverman
                  Thanks barnosch,
                  I think I’ve solved the problem: D
                  I think because I’m working remotely and I can not see if the stream is shown or not but I trust.
                  I practically lost a pass that eliminated the sound.
                  So I think that everything is resolved.
                  I see the stable connection from the remote console and then almost for sure that the module now works.
                  I find it in issue.
                  The command it solves is:
                  git fetch - all
                  git checkout nosound
                  I’ll let you know as soon as I see it with my eyes
                  • A
                    alverman
                    Solved !!
                      shbatm Module Developer
                      @alverman – I’m the creator of the module and I wanted to apologize, I’ve been working on other projects and not following this forum very closely the past few months. I’m glad you got everything solved, I’m sorry I wasn’t able to assist.
                      In the future, if you have any issues with one of the modules I created, please tag me (@shbatm) or open an issue on the module’s Issue page at github.com so I get a notification and will be happy to assist.
                        sepulvar
                        Can you share your final configuration?
