    Magic Mirror showing only black screen on PiZeroW -- node serveronly mode
    3 Posts 2 Posters 1.9k Views 2 Watching
    • K Offline
      kevenp
      I am new to Raspberry Pi so apologies if i’m doing some schoolboy errors
      I successfully installed Raspbian Stretch - kernel version 4.9 on my new PI ZERO W, i also setup the Wifi Etc and was able to surf the internet from my PI. I also then enabled SSH, VNC etc and was able to remotely connect.
      I then installed Magic mirror using the Auto Installer … so far all Good.
      I then got myself an API key from openweathermap.org and created the config.js and updated the API - Key and the Location Id to my city in this file.
      Next, i ran the command npm run config:check and i did not get any errors
      I finally tried to load this in Iceweasel (firefox) and all i get is a Black Screen and nothing else - i don’t get any errors on firebug as well – I have also tried the same on Midori and chromium and no luck on either. infact with Midori i get a Page not found error.
      i have also uploaded the file to jslint.com and only get use space not tabs warnings…no errors
      Any form of help much appreciated
        MrNonoss
        If I remember correctly, I had a similar issue once.
        Can you try “npm install” while in the MagicMirror directory?
        • K Offline
          kevenp
          Works a treat mate - thanks for the Help - Much appreciated !!
