    MMM-gtasks errors: Error while trying to retrieve access token
    5 Posts 2 Posters 3.7k Views 2 Watching
    • E Offline
      Esinem
      Re: MMM-gtasks - Google tasks for your mirror
      Problem loading tasks.
      Try running the mirror with node serveronly for extra info
      Follow the guide in the readme.md
      Have you downloaded your 'client_sectet.json'?
      Have you ran initialy with node serveronly and followed the link provided?
      I think my problems relates to my client_secret.json. In the installation guide it says “Download your client_secret.json file by following the guide linked below” except I couldn’t find any guide so just winged it. I assume what I did was incorrect as this is what I got:
      Ready to go! Please point your browser to: http://localhost:8080
      TypeError: Cannot read property 'client_secret' of undefined
          at authorize (/home/pi/MagicMirror/modules/MMM-gtasks/GoogleTasks.js:34:51)
          at processClientSecrets (/home/pi/MagicMirror/modules/MMM-gtasks/GoogleTasks.js:112:19)
          at FSReqWrap.readFileAfterClose [as oncomplete] (fs.js:447:3)
      UPDATE:
      This what I get now:
      Error while trying to retrieve access token { Error: invalid_grant
      at Request._callback (/home/pi/MagicMirror/modules/MMM-gtasks/node_modules/google-auth-library/lib/transporters.js:81:15)
      at Request.self.callback (/home/pi/MagicMirror/modules/MMM-gtasks/node_modules/request/request.js:186:22)
      at emitTwo (events.js:106:13)
      at Request.emit (events.js:191:7)
      at Request. (/home/pi/MagicMirror/modules/MMM-gtasks/node_modules/request/request.js:1163:10)
      at emitOne (events.js:96:13)
      at Request.emit (events.js:188:7)
      at IncomingMessage. (/home/pi/MagicMirror/modules/MMM-gtasks/node_modules/request/request.js:1085:12)
      at IncomingMessage.g (events.js:292:16)
      at emitNone (events.js:91:20) code: 400 }
      Token stored to ./modules/MMM-gtasks/gtasks_token.json
      Now, the screen appears but no error from my Tasks, just says Loading and seems stalled.
      Any help gratefully received. Assume you are explaining to Homer Simpson :-)
      • E Offline
        Esinem @Esinem
        Anybody?
        • N Offline
          ninjabreadman
          Hey @Esinem,
          In GoogleTasks.js:100 it has the following URL: https://developers.google.com/google-apps/tasks/quickstart/nodejs#step_1_turn_on_the_api_name
          Recommend you follow Step 1, that should yield your client_secret.json.
          Let us know how you fare.
          Problem with config or JavaScript? Copy/paste it into JSHint.
          Check out the detailed walkthroughs on install, config, modules, etc.
          E 2 Replies Last reply Reply Quote 0
          • E Offline
            Esinem @ninjabreadman
            @ninjabreadman Thanks a ton! Unfortunately, the instructions were referred to but not included in the installation instructions as far as I could see.
            • E Offline
              @ninjabreadman Hmm, unfortunately, no change :-( I ran node serveronly but I couldn’t see any errors. Debug is true in config.js
              pi@raspberrypi:~ $ cd /home/pi/MagicMirror
              pi@raspberrypi:~/MagicMirror $ node serveronly
              Starting MagicMirror: v2.1.3
              Loading config …
              Loading module helpers …
              Initializing new module helper …
              Module helper loaded: MMM-gtasks
              All module helpers loaded.
              Starting server on port 8080 …
              Server started …
              Connecting socket for: MMM-gtasks
              Starting node helper for: MMM-gtasks
              Starting module: newsfeed
              Sockets connected & modules started …
