    Yet Another Voice Module (Sphinx + Alexa)
    40 Posts 6 Posters 37.4k Views 6 Watching
    • C Offline
      clumsy_ninja @whyjustin
      @whyjustin said in Yet Another Voice Module (Sphinx + Alexa):
       commands: {
          "mirror mirror": {
            action: 'alexa'
      If you edit the above you can adjust the activation of Alexa. Haven’t spent much time with this project recently but IIRC you have to remove sphinx-model-generator/commands.dic and sphinx-model-generator/commands.lm when changing the commands
      @whyjustin Yeah thats it. Do i need to record a new training file to replace those or where did the original one come from?
      • L Offline
        lb-rezende @whyjustin
        @whyjustin
        I followed this doc that you linked and it has more details than the original readme file that I used, when I used the automated installation. The problem now is that Maven is no longer working. I receive the following message:
        -Dmaven.multiModuleProjectDirectory system property is not set. Check $M2_HOME environment variable and mvn script match.
        Any idea how to solve it?
        • W Offline
          whyjustin @clumsy_ninja
          @clumsy_ninja said in Yet Another Voice Module (Sphinx + Alexa):
          The plugin will automatically generate your models and dictionary on startup using the JSON property names (e.g. “mirror mirror”) if the sphinx-model-generator/commands.dic and sphinx-model-generator/commands.lm are missing. So remove those files, adjust the JSON, then start the plugin again. You can also manually edit the commands.lm and commands.dic files after they are automatically generated if you are comfortable with language modeling.
          • W Offline
            whyjustin @lb-rezende
            @lb-rezende said in Yet Another Voice Module (Sphinx + Alexa):
            I would verify your Maven installation. Is $M2_HOME set? If so you can -Dmaven.multiModuleProjectDirectory=$M2_HOME although this should be the default behavior.
            • L Offline
              Where do I set the $M2_HOME (and how)? I just created the maven.sh file as described in the tutorial and included the two lines. I inserted this line that you suggested in the same file, maven.sh, but did not work.
              Is there a way to uninstall those applications and do all over again?
              • W Offline
                Looks like the $M2_HOME is set in the script
                export M2_HOME=/opt/apache-maven-3.3.9
                If the script resides in /etc/profile.d/ then it should run during boot (have you restarted your pi at all?).
                Easiest would be to nuke the entire thing and start over. TBH these are linux questions and I’m very happy to support my plugin but they seem beyond the scope of that. I’ll try my best to help but may not be able to provide support on every question.
                • L Offline
                  lb-rezende
                  @whyjustin
                  Thanks for your help. I formatted the SD card and installed all over again, but it has something that does not work.
                  I have Alexa working, I used the following guide:
                  https://github.com/alexa/alexa-avs-sample-app/wiki/Raspberry-Pi
                  So, following the README of your module, I have the following:
                  VLC:
                  VLC media player 2.2.1 Terry Pratchett (Weatherwax) (revision 2.2.1-0-ga425c42)
                  JAVA
                  java version “1.8.0_111”
                  Java™ SE Runtime Environment (build 1.8.0_111-b14)
                  Java HotSpot™ Client VM (build 25.111-b14, mixed mode)
                  javac 1.8.0_111
                  So ALPN is configured to 8.1.0.v20141016 (1.8.0u11 OpenJDK version)
                  MAVEN
                  Apache Maven 3.0.5
                  Maven home: /usr/share/maven
                  Java version: 1.8.0_111, vendor: Oracle Corporation
                  Java home: /usr/lib/jvm/java-8-oracle/jre
                  Default locale: en_GB, platform encoding: UTF-8
                  OS name: “linux”, version: “4.4.35-v7+”, arch: “arm”, family: “unix”
                  I configured config.js with the following sets and after that executed npm install in the module directory:
                                      module: 'magic-mirror-voice',
                                      header: 'Magic Mirror Voice',
                                      position: 'top_right',
                                              debug: true,
                                              alexa: {
                                                      productId: 'my_device',
                                                      dsn: '1xxxxxxxxxx'
                                              ssl: {
                                                      sslCaCert: '',
                                                      sslKey: '',
                                                      sslCert: '',
                                                      sslClientKeyStore: '',
                                                      sslClientKeyStorePassphrase: ''
                                              companion: {
                                                      port: 3000,
                                                      serviceUrl: 'https://localhost:3000',
                                                      redirectUrl: 'https://localhost:3000/authresponse',
                                                      clientId: '.MY PRIVATE KEY',
                                                      clientSecret: 'MY PRIVATE KEY'
                                              client: {
                                                      alpnVersion: '8.1.0.v20141016',
                                                      vlcPath: '/usr/lib/vlc',
                                                      vlcPluginPath: '/usr/lib/vlc/plugins'
                                              sphinx: {
                                                      commands: {
                                                              "mirror mirror": {
        action: 'alexa'
                                                      dictionary: './commands.dic', // Optional
                                                      model: './commands.lm' // Optional
                  I removed the ssl optional configuration, the port is the same that is configured at the amazon developer site, the clientId and clientSecret are correct (I removed here), the ALPN version is the same of Java and the vlc address is correct, so it should be working, but I receive the following message:
                  Whoops! There was an uncaught exception…
                  TypeError: parser.close is not a function
                  at SAXStream.openf1 (/home/pi/MagicMirror/node_modules/feedme/lib/xmlfeedparser.js:107:14)
                  at emitOne (events.js:96:13)
                  at SAXStream.emit (events.js:188:7)
                  at Object.me._parser.(anonymous function) [as onopentag] (/home/pi/MagicMirror/node_modules/sax/lib/sax.js:258:17)
                  at emit (/home/pi/MagicMirror/node_modules/sax/lib/sax.js:640:35)
                  at emitNode (/home/pi/MagicMirror/node_modules/sax/lib/sax.js:645:5)
                  at openTag (/home/pi/MagicMirror/node_modules/sax/lib/sax.js:841:5)
                  at Object.write (/home/pi/MagicMirror/node_modules/sax/lib/sax.js:1318:13)
                  at SAXStream.write (/home/pi/MagicMirror/node_modules/sax/lib/sax.js:239:18)
                  at yoshi.write (/home/pi/MagicMirror/node_modules/feedme/lib/feedme.js:41:14)
                  at IconvLiteDecoderStream.ondata (_stream_readable.js:555:20)
                  at IconvLiteDecoderStream.emit (events.js:188:7)
                  at readableAddChunk (_stream_readable.js:176:18)
                  at IconvLiteDecoderStream.Readable.push (_stream_readable.js:134:10)
                  at IconvLiteDecoderStream.Transform.push (_stream_transform.js:128:32)
                  Do you have any idea of what is happening?
                  • W Offline
                    Looking through the stack trace it looks like this is unrelated to my plugin.
                      Mirrorolentia
                      @whyjustin: I have integrated your module into other modules. However, am seeing the following problems:
                      1. Saying “mirror mirror” doesn’t trigger Alexa. Do the AVS sample apps need to be started alongside?I tried that but your module was exiting with an exception:
                        Unable to run Listen in Sphinx Java Client:Error: Error running instance method
                        java.lang.NullPointerException
                        at com.amazon.alexa.avs.AudioCapture.startCapture(AudioCapture.java:74)
                        at com.amazon.alexa.avs.AudioCapture.getAudioInputStream(AudioCapture.java:56)
                        at com.whyjustin.magicmirror.sphinx.SphinxMirrorRecognizer.startRecognition(SphinxMirrorReroot@raspberrypi:/home/pi/MagicMirror/MagicMirror-master/modules/magic-mirror-voice
                      2. There are few errors:
                        Error with Alexa Companion Service: { [Error: Not Found] status: 404 }
                      Please let me know where am I going wrong.
                      • C Offline
                        clumsy_ninja
                        @Mirrorolentia If you can’t get that one to work or want to try a different one checkout AlexaPi. It’s a python implementation of Alexa made for all sorts of platforms.
                        You can get it from here: https://github.com/alexa-pi/AlexaPi
                        You can also use this mirror module to give status feedback on the mirror: https://github.com/dgonano/MMM-AlexaPi
                        Just be sure to pick the magicmirror platform during setup instead of the default raspberrypi
                        • 4 / 4
