    How to display a local static html file...
    4 Posts 3 Posters 3.8k Views 3 Watching
      Deplorable
      I have tried all of the various iFrame modules and while I can display sites ( for example www.bing.com) I have failed utterly in displaying a local html file (/home/pi/intro.html). The file is very basic and works just fine in all browsers I have tested it on. Is there a module that will display this file? Thanks!
      N E D 3 Replies Last reply Reply Quote 0
      • N Offline
        ninjabreadman @Deplorable
        @Deplorable Have you tried the file:// protocol? (e.g. file:///home/pi/intro.html)?
        Otherwise, every module can make files available through a public subfolder. So I think you can make a public folder under your iFrame module and serve from that (e.g. http://localhost:8080/modules/iframe/public).
        Problem with config or JavaScript? Copy/paste it into JSHint.
        Check out the detailed walkthroughs on install, config, modules, etc.
        • E Offline
          E3V3A @Deplorable
          @Deplorable If you’re using an iFrame module, you probably need to use the file:///.../path/to/module/to/file.html. Check what you Browser DevTools (CTRL-SHIFT-I) says. If you need access to file from an outside browser, you need the correct Module URL.
          "Everything I do (here) is for free – altruism is the way!"
          MMM-FlightsAbove, MMM-Tabulator, MMM-Assistant (co-maintainer)
            Deplorable @Deplorable
            @Deplorable I found the solution I was looking for:
            https://github.com/eouia/MMM-HTMLBox.
            For whatever reason it isn’t listed on the “3rd Party Module” page although it should be… Works fine. Thanks for the solutions offered re: iFrame…
