PM2 woes.
Decided to build a pi3 with Alexapi and MM. It all seemed to go well although I have yet to add the MM Alexa extensions.
The problem I am having is after installation PM2 starts MM fine using pm2 start MagicMirror.
If I then reboot I get the MM splash screen during boot but the application does not display. If I open a terminal and run pm2 start MagicMirror it shows online but nothing displays. I have to run npm start to get it to kick off. I am now at a bit of a loss as to what to do next.
Phill
Looking at the logs I see
Error: ENOENT: no such file or directory, open 'package.json' at Error (native) at Object.fs.openSync (fs.js:642:18) at Object.fs.readFileSync (fs.js:510:33) at Object. (/home/pi/MagicMirror/js/app.js:15:32) at Module._compile (module.js:577:32) at Object.Module._extensions..js (module.js:586:10) at Module.load (module.js:494:32) at tryModuleLoad (module.js:453:12) at Function.Module._load (module.js:445:3) at Module.require (module.js:504:17)Starting MagicMirror: v2.2.2 Loading config ... Loading module helpers ... No helper found for module: alert. Initializing new module helper ... Module helper loaded: updatenotification No helper found for module: clock. Initializing new module helper ... Module helper loaded: calendar No helper found for module: compliments. No helper found for module: currentweather. No helper found for module: weatherforecast. Initializing new module helper ... Module helper loaded: newsfeed All module helpers loaded. Starting server on port 8080 ... Server started ... Connecting socket for: updatenotification Connecting socket for: calendar Starting node helper for: calendar Connecting socket for: newsfeed Starting module: newsfeed Sockets connected & modules started ... Launching application. Create new calendar fetcher for url: http://www.calendarlabs.com/templates/ical/US-Holidays.ics - Interval: 300000 Create new news fetcher for url: http://www.nytimes.com/services/xml/rss/nyt/HomePage.xml - Interval: 300000 Can't parse feed item: { title: '', link: 'https://www.nytimes.com//?partner=rss&emc=rss', guid: { ispermalink: 'true', text: 'https://www.nytimes.com//' }, 'atom:link': { rel: 'standout', href: 'https://www.nytimes.com//?partner=rss&emc=rss' }, description: '', 'dc:creator': '', pubdate: '' } Title: Description: Pubdate: undefined Can't parse feed item: { title: '', link: 'https://www.nytimes.com//?partner=rss&emc=rss', guid: { ispermalink: 'true', text: 'https://www.nytimes.com//' }, 'atom:link': { href: 'https://www.nytimes.com//?partner=rss&emc=rss', rel: 'standout' }, description: '', 'dc:creator': '', pubdate: '' } Title: Description: Pubdate: undefined Can't parse feed item: { title: '', link: 'https://www.nytimes.com//?partner=rss&emc=rss', guid: { ispermalink: 'true', text: 'https://www.nytimes.com//' }, 'atom:link': { href: 'https://www.nytimes.com//?partner=rss&emc=rss', rel: 'standout' }, description: '', 'dc:creator': '', pubdate: '' } Title: Description: Pubdate: undefined
