    IO reference error on calendar & newsfeed
    1 Posts 1 Posters 1.1k Views 1 Watching
      ascore5000
      Hi everybody,
      i have a problem with my magic mirror implementation.
      If I use a fresh download of MM2 and activate in the config file the newsfeed or the calendar, I got an error on the console:
      ReferenceError: io is not defined
      Stack:
      MMSocket() socketclient.js:11 Module<.socket() module.js:160 Module<.sendSocketNotification() module.js:298 .addCalendar() calendar.js:279 .start() calendar.js:67 startModules() loader.js:55 loadModules/loadNextModule/<() loader.js:40 loadFile/stylesheet.onload() loader.js:190
      The error occurs on socetclient.js on line 11.
      My config file:
      			module: 'newsfeed',
      			position: 'bottom_bar',
      				feeds: [
      						title: "New York Times",
      				showSourceTitle: true,
      				showPublishDate: true
      			module: 'calendar',
      			header: 'US Holidays',
      			position: 'top_right',
      						symbol: 'calendar-check-o ',
      						url: 'webcal://www.calendarlabs.com/templates/ical/US-Holidays.ics'
      If I comment this lines out, the time and the weather is working.
      I hope you can help me, thank you!
      ascore5000
      Note from admin: Please use Markdown on code snippets for easier reading!
