    Installing USB Soundcard using seperate USB Mic
    12 Posts 3 Posters 7.5k Views 3 Watching
    • MrCoffeeM Offline
      MrCoffee @E3V3A
      @e3v3a said in Installing USB Soundcard using seperate USB Mic:
      dtparam=audio=off
      I just tried it. Unfortunately with no luck.
      Sound still comes from the audio jack.
      • MrCoffeeM Offline
        MrCoffee
        I reinstalled the whole system using another SD-card.
        Now I can use the seperate USB-Mic and the audio Out comes from the other USB-Soundcard.
        After that I installed all my modules like MMM-Podcast.
        I played the video and … sound comes from the audio jack again:-(
        However the usb mic and alexa are still working fine. It is just MMM-Podcast which uses the audio jack.
        How can that be? I installed the dependecies especially the omxplayer. But that can´t be the reason, or what do you think?
        lsusb
        Bus 001 Device 004: ID 0d8c:013c C-Media Electronics, Inc. CM108 Audio Controller
        Bus 001 Device 005: ID 0d8c:0014 C-Media Electronics, Inc.
        Bus 001 Device 003: ID 0424:ec00 Standard Microsystems Corp. SMSC9512/9514 Fast Ethernet Adapter
        Bus 001 Device 002: ID 0424:9514 Standard Microsystems Corp. SMC9514 Hub
        Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
        aplay -l
        **** Liste der Hardware-Geräte (PLAYBACK) ****
        Karte 0: Device_1 [USB Audio Device], Gerät 0: USB Audio [USB Audio]
          Sub-Geräte: 1/1
          Sub-Gerät #0: subdevice #0
        sudo nano ~/.asoundrc
        pcm.!default {
            type asym
            playback.pcm "plughw:0"
            capture.pcm  "plughw:1"
        ctl.!default {
                type hw
                card 0
        Do you have an idea? Seems like I am almost there.
        Thanks.
