    • Search
    MagicMirror² v2.24.0 is available! For more information about this release, check out this topic.
    UNSOLVED Odroid C1+ warnings at the end of the installation
    Troubleshooting
    • I
      itsmaxdd last edited by
      I’m currently receveing the following warnings on my odroid C1+
      npm WARN lifecycle magicmirror@2.3.1~install: cannot run in wd %s %s (wd=%s) magicmirror@2.3.1 cd vendor && yon install /root/MagicMirror
      npm WARN lifecycle magicmirror@2.3.1~postinstall: cannot run in wd %s %s (wd=%s) magicmirror@2.3.1 sh installers/postinstall/postinstall.sh && yon run install-fonts /root/MagicMirror
      npm WARN grunt-stylelint@0.10.0 requires a peer of stylelint@^9.0.0 but none is installed. You must install peer dependencies yourself.
      Right now i’m using a Debian Jessie headless version with nodejs 8 and npm 5.6. Should i migrate to a desktop version? I guess so…
      Regards,
      • I
        Should i yon install /root/MagicMirror in vendor folder?
        Should i run postinstall.sh and yon run install-fonts /root/MagicMirror manually? Should i install stylelint manuall?
        • I
          It may be related with the fact that i’m root.
          I’ll try the following npm install --unsafe-perm to see if it works
