    MMM-FHEM shows values from FHEM devices ...
    40 Posts 14 Posters 37.9k Views 15 Watching
      dominic
      Hi everyone
      I’ve tried to install and activate the MMM-FHEM module but with not to much success. There was actually no problem neither with the installation nor the configuration but I can’t get it running.
      FHEM is running on the Rpi.
      Here is my config.js.
      //FHEM
          module: 'MMM-FHEM',
          position: 'bottom_bar',
            host: ['localhost'],
            port: '8083',
            https: false,
            devices: [
                        { deviceName: 'ESPEasy_ESP_Test_DHT',
                          deviceReadings: [
                                            { name: 'Temperatur', icon: 'wi wi-thermometer', suffix: '°' },
                                            { name: 'sate', icon: 'wi wi-humidity', suffix: 'test%' },
      i hope you can help me.
      greetings from Germany
        BenRoe Module Developer @dominic
        @dominic remove the squared brackets from the host row.
          BenRoe Module Developer @Da-ne-ezy
          @Da-ne-ezy hi currently i have no time to research how to implement that from nodejs side.
          If someone has an idea, please do a pull request on github.
            dominic @BenRoe
            @BenRoe thanks for the answer. I have removed the squared brackets but it is still the same. The modul will not displayed. Do you have an other idea ?
              DerRheingold
              I have a similar issue: after installing the module and adding it to the config.js I don’t see it on the screen. After a restart all other widgets are shown. I don’t even see an empty field or such where this widget should be shown :(
              Am I missing anything maybe?
              For the sake of debugging, I’m trying to access a publicly available FHEM instance.
              			module: 'MMM-FHEM',
              			position: 'top_bar',
              				host: 'http://fhem.waschto.eu',
              				port: '8083',
              				https: false,
              				devices: [
              					  { deviceName: 'FL_Temperatur',
              						deviceReadings: [
              										  { name: 'temperature', icon: 'wi wi-thermometer', suffix: '°' },
              										  { name: 'humidity', icon: 'wi wi-humidity', suffix: '%' },
              Might I have made a mistake installing the dependencies? Is “sudo npm install underscore” or “request” not the right way to do it?
                @Da-ne-ezy try this.
                host: 'username:password@ip-of-your-fhem-server'
                Please let me know if it works.
                Da-ne-ezyD 1 Reply Last reply Reply Quote 0
                • Da-ne-ezyD Offline
                  Da-ne-ezy @BenRoe
                  @BenRoe Sorry doesn’t work for me. The module doesn’t even appear. My config should be fine…
                  	module: 'MMM-FHEM',
                  			host: 'xxxx:xxxx@xxx.xxx.xxx.xx',
                  			port: '8083',
                  			https: true,
                  				devices: [
                  					{ deviceName: 'WZ_Heizung_Clima',
                  						deviceReadings: [
                  						{ name: 'measured-temp', icon: 'wi wi-thermometer', suffix: '°' },
                  						{ name: 'desired-temp', icon: 'wi wi-thermometer', suffix: '°' },
                  FREE IT-Projects and Raspberry Pi Tutorials on my Website: www.danykilian.com
                    Too bad, someone mention this on the github ticket. https://github.com/BenRoe/MMM-FHEM/issues/2
                    I don’t have the time to examine this problem. If someone can implement this, please let me know.
                      Robs
                      the Fix for you`r Problem might be:
                      Disable csrfToken
                      after 2 weeks of searching the Internet i found the post in this forum this helpt me to fix the same probelm.
                      • rudibaraniR Offline
                        rudibarani Project Sponsor @BenRoe
                        This post is deleted!
                        • 4 / 4
