    blank screen?
    3 Posts 2 Posters 1.8k Views 3 Watching
    • zdenekZ Offline
      zdenek
      Hi all
      I’ve no idea, what happend. In the morning was everything OK, when I came home, there was just blank screen. I did restart of Raspberry, I can see it booting, but then, instead of running MM, there is just blank screen. But when I connect to ip_of_raspberry:8080 from my laptop, it normally works, I can see modules…
      I’ve tried use default config.js - still blank screen
      this I get via “dev”
      translations.js:62 Uncaught SyntaxError: Invalid or unexpected token
      module.js:295 Uncaught SyntaxError: Unexpected identifier
      loader.js:155 Uncaught SyntaxError: Invalid or unexpected token
      main.js:447 Initializing MagicMirror.
      translator.js:200 Uncaught ReferenceError: translations is not defined
          at Object.loadCoreTranslations (translator.js:200)
          at Object.init (main.js:449)
          at main.js:577
      any idea?
      Thanks, Zdeněk
      zdenekZ 1 Reply Last reply Reply Quote 0
      • zdenekZ Offline
        zdenek @zdenek
        @zdenek this row makes the problem
        address: "0.0.0.0",
        in config. Without this row doesn’t work access to ip_of_raspberry:8080
        why is it wrong?
          sdetweil @zdenek
          @zdenek sounds like something else (some other application or process) is listening on port 8080
