    NPM install is giving Error.
    18 Posts 11 Posters 29.4k Views 11 Watching
    • N Offline
      NoNameRo @fire1ce
      @fire1ce
      try
      curl -sL https://deb.nodesource.com/setup_8.x | sudo -E bash -
      sudo apt-get install -y nodejs
      npm install -g npm@latest
      • F Offline
        fire1ce @NoNameRo
        @nonamero said in NPM install is giving Error.:
        @fire1ce
        try
        thanks. that helps.
          dnwmhaha @NoNameRo
          @nonamero
          Hi, Thank you for your help. I have been trying to install MM. At first, I had a trouble installing electron and node. Now I got dependencies error.
          I’ve tried what you suggested and I got the following error.
          During the installation of MM, I got Unable to install dependencies!.
          Could you please help?
          //your code here
          pi@raspberrypi:~ $ bash -c "$(curl -sL https://raw.githubusercontent.com/MichMich/MagicMirror/master/installers/raspberry.sh)"
          $$$\    $$$ |                    \__|          $$$\    $$$ |\__|                                        $$  __$$\
          $$$$\  $$$$ | $$$$$$\   $$$$$$\  $$\  $$$$$$$\ $$$$\  $$$$ |$$\  $$$$$$\   $$$$$$\   $$$$$$\   $$$$$$\  \__/  $$ |
          $$\$$\$$ $$ | \____$$\ $$  __$$\ $$ |$$  _____|$$\$$\$$ $$ |$$ |$$  __$$\ $$  __$$\ $$  __$$\ $$  __$$\  $$$$$$  |
          $$ \$$$  $$ | $$$$$$$ |$$ /  $$ |$$ |$$ /      $$ \$$$  $$ |$$ |$$ |  \__|$$ |  \__|$$ /  $$ |$$ |  \__|$$  ____/
          $$ |\$  /$$ |$$  __$$ |$$ |  $$ |$$ |$$ |      $$ |\$  /$$ |$$ |$$ |      $$ |      $$ |  $$ |$$ |      $$ |
          $$ | \_/ $$ |\$$$$$$$ |\$$$$$$$ |$$ |\$$$$$$$\ $$ | \_/ $$ |$$ |$$ |      $$ |      \$$$$$$  |$$ |      $$$$$$$$\
          \__|     \__| \_______| \____$$ |\__| \_______|\__|     \__|\__|\__|      \__|       \______/ \__|      \________|
                                  \______/
          Updating packages ...
          Hit:1 http://raspbian.raspberrypi.org/raspbian stretch InRelease
          Get:2 http://archive.raspberrypi.org/debian stretch InRelease [25.3 kB]
          Hit:3 https://deb.nodesource.com/node_8.x stretch InRelease
          Fetched 25.3 kB in 1s (13.7 kB/s)
          Reading package lists... Done
          Installing helper tools ...
          Building dependency tree
          Reading state information... Done
          build-essential is already the newest version (12.3).
          curl is already the newest version (7.52.1-5+deb9u6).
          git is already the newest version (1:2.11.0-3+deb9u3).
          unzip is already the newest version (6.0-21).
          wget is already the newest version (1.18-5+deb9u2).
          0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
          Check current Node installation ...
          Node currently installed. Checking version number.
          Minimum Node version: v5.1.0
          Installed Node version: v5.7.0
          No Node.js upgrade necessary.
          Cloning MagicMirror ...
          Cloning into 'MagicMirror'...
          remote: Counting objects: 276, done.
          remote: Compressing objects: 100% (245/245), done.
          remote: Total 276 (delta 34), reused 129 (delta 21), pack-reused 0
          Receiving objects: 100% (276/276), 383.32 KiB | 688.00 KiB/s, done.
          Resolving deltas: 100% (34/34), done.
          Cloning MagicMirror Done!
          Installing dependencies ...
          /home/pi/.nvm/versions/node/v5.7.0/lib/node_modules/npm/bin/npm-cli.js:82
                let notifier = require('update-notifier')({pkg})
          SyntaxError: Block-scoped declarations (let, const, function, class) not yet supported outside strict mode
              at exports.runInThisContext (vm.js:53:16)
              at Module._compile (module.js:387:25)
              at Object.Module._extensions..js (module.js:422:10)
              at Module.load (module.js:357:32)
              at Function.Module._load (module.js:314:12)
              at Function.Module.runMain (module.js:447:10)
              at startup (node.js:141:18)
              at node.js:933:3
          pi@raspberrypi:~ $
            Alex_
            @postremalone said in NPM install is giving Error.:
            NPM install is giving error.
            alt text
            Help please.
            I meet the same issue than you and I solved it by uninstalling nodejs
            sudo apt-get remove nodejs
            and reinstall nodejs by using the MagicMirror install script
            During the installation, npm install -g npm@latest give me this error
            npm ERR! path /usr/lib/node_modules/npm/node_modules/ansi-regex
            npm ERR! code EACCES
            npm ERR! errno -13
            npm ERR! syscall access
            npm ERR! Error: EACCES: permission denied, access '/usr/lib/node_modules/npm/node_modules/ansi-regex'
            npm ERR!  { Error: EACCES: permission denied, access '/usr/lib/node_modules/npm/node_modules/ansi-regex'
            npm ERR!   stack: 'Error: EACCES: permission denied, access \'/usr/lib/node_modules/npm/node_modules/ansi-regex\'',
            npm ERR!   errno: -13,
            npm ERR!   code: 'EACCES',
            npm ERR!   syscall: 'access',
            npm ERR!   path: '/usr/lib/node_modules/npm/node_modules/ansi-regex' }
            npm ERR!
            npm ERR! Please try running this command again as root/Administrator.
            and I run same command as root to solved this
            sudo npm install -g npm@latest
            Here is version of nodejs install by MagicMirror script :
            Installed Node version: v9.11.2
            • E Offline
              epi
              > magicmirror@2.4.1 start /home/pi/MagicMirror
              > sh run-start.sh
              /home/pi/MagicMirror/node_modules/electron/index.js:1
              (function (exports, require, module, __filename, __dirname) {
              SyntaxError: Invalid or unexpected token
                  at new Script (vm.js:51:7)
                  at createScript (vm.js:136:10)
                  at Object.runInThisContext (vm.js:197:10)
                  at Module._compile (internal/modules/cjs/loader.js:618:28)
                  at Object.Module._extensions..js (internal/modules/cjs/loader.js:665:10)
                  at Module.load (internal/modules/cjs/loader.js:566:32)
                  at tryModuleLoad (internal/modules/cjs/loader.js:506:12)
                  at Function.Module._load (internal/modules/cjs/loader.js:498:3)
                  at Module.require (internal/modules/cjs/loader.js:598:17)
                  at require (internal/modules/cjs/helpers.js:11:18)
              npm ERR! code ELIFECYCLE
              npm ERR! errno 1
              npm ERR! magicmirror@2.4.1 start: `sh run-start.sh`
              npm ERR! Exit status 1
              npm ERR!
              npm ERR! Failed at the magicmirror@2.4.1 start script.
              npm ERR!     /home/pi/.npm/_logs/2018-09-13T10_40_56_673Z-debug.log
                devinhedge @NoNameRo
                @nonamero I’ve brought this up on another thread, but I’ll mention here so that it is captured in context: for the last couple months Node.js and npm are currently BROKEN on RaspberryPi.
                I just tried a test this morning using the started Electron app at https://electronjs.org/docs/tutorial/first-app
                Running the automated install is a Red Herring. It is inappropriate to suggest it.
                We have to figure out how to fix the bugs in the Node.js installation for Raspberry Pi before anything else. I’m wondering if installing an older version of Node.js is the solution. If so, then what version would we start with?
                • P Offline
                  paddyhughes @postremalone
                  @postremalone
                  I just installed a module and it asked me to update NPM think i did it in the root directory not MagicMirror one can be sure.
                  This is what worked for me
                  sudo npm i -g npm
                    rmeskill
                    Aha-got it!
                    sudo rm -rf ~/.nvm
                    sudo rm /usr/local/bin/node
                    sudo rm /usr/local/bin/nvm
                    pm2 stop mm (not sure if I missed this earlier)
                    This installed fine, but gave me an error of an out-of-date npm version, so I ran:
                    sudo npm i -g npm
                    Then moved all my old modules and config file over to the new install and checked my node/npm versions:
                    pi@raspberrypi:~/MagicMirrorBackup/modules $ node -v
                    v9.11.2
                    pi@raspberrypi:~/MagicMirrorBackup/modules $ npm -v
                    6.5.0
                    So they’re not as up-to-date as my previous ones, but MagicMirror is working fine!
                    Thanks everyone for the input, turns out just a bit of manual removal and persistence sorted me out!
