    Interaction Newsfeed
    3 Posts 2 Posters 2.1k Views 2 Watching
    • V Offline
      Vunara
      Hello,
      I am looking for a way, help to add interaction with newsfeed from Voice control.
      In News Feed module page we can see notification mechanism.
      ARTICLE_NEXT
      ARTICLE_PREVIOUS
      ARTICLE_MORE_DETAILS
      I am loose, I don’t no witch module I need to use and how. MMM-Gaction, MMM-Hotword or MMM-NotificationTrigger?
      MMM-NotificationTrigger seem give some example, but my little experience block me.
      Maybe someone can help me?
      MMM-AssistantMk2 and MMM-Hotword work fine.
      I Love MagicMirror project!
      • ? Offline
        A Former User @Vunara
        @vunara
        AssistantMk2 can provide 3 kinds of method; Transcription Hooking, IFTTT, GAction.
        For beginners; I recommend to use IFTTT, but simply, I show you how to use TranscriptionHooking
        (TranscriptionHooking is not so good way, because, Assistant couldn’t really understand what you were saying.)
        Anyway,
        modify AssistantMk2 section in your config.js
        transcriptionHook: {
          "NEXTNEWS" : "next news"
        This means, Module will catch “next news” from your voice when you activate Assistant.
        add this inside triggers: [] of NotificationTrigger section
          trigger: "ASSISTANT_HOOK",
          triggerPayloadFilter: (payload) => {
            if (payload.hook == "NEXTNEWS") {
              return true
            } else {
              return false
          fires: [
               fire:"ARTICLE_NEXT",
        I didn’t test this on a real device,(I’m not in front of my device currently) But You can catch the idea.
        • V Offline
          Vunara @Guest
          @sean Thanks for reply and explain, that will help me a lot
