    sendnotification mmm-swipe to mmm-Pages
    5 Posts 2 Posters 3.0k Views 2 Watching
    • F Offline
      fischi87
      Hello guys,
      i try to change a page with a swipe. i installed the mmm-Swipe and mmm-pages module. i have 2 pages right now but i don’t understand how can i change the pages with a swipe. i don’t know where i should write down the send notification in with .js file. have someone a example for me or can tell me how it will work?
      • ? Offline
        A Former User @fischi87
        @fischi87 With MMM-NotificationTrigger you could.
          module: "MMM-NotificationTrigger",
            triggers:[
                trigger: "MOVEMENT",
                triggerPayloadFilter: (payload) => {
                  if (payload == "Swipe Left") {
                    return true
                  } else {
                    return false
                fires: [
                    fire:"PAGE_DECREMENT",
                  if (payload == "Swipe Right") {
                    return true
                  } else {
                    return false
                fires: [
                    fire:"PAGE_INCREMENT",
        Not real tested, but you can get an idea.
        • F Offline
          fischi87
          thanks for ur time.
          when i run
          npm run config:check
          i get just this errors:
          Line 131 col 77 'arrow function syntax (=>)' is only available in ES6 (use 'esversion: 6').
          Line 139 col 101 'arrow function syntax (=>)' is only available in ES6 (use 'esversion: 6').
          greedings
          • ? Offline
            @fischi87
            When your node version is low, those errors will come.
            You can use this format instead arrow function.
            Instead;
            (args) => {…}
            Use this;
            function (args) {…}
            Ex;
            triggerPayloadFilter: function (payload) {
            • F Offline
              fischi87
              I will try of course.
              Thank u really so much.
              Anyway also with this „error“ it works Fine 😍
