    THe install of addon doesnt work 100%
    1 Posts 1 Posters 921 Views 1 Watching
      DawnLord
      This is really awesome but i cannot get it to work 100%
      For example sensors and thermometers will not show.
      Could anyone see whats wrong?
      Using addon to Hass.IO
      /* Magic Mirror Config for HASS.IO
       * Orginal by Michael Teeuw http://michaelteeuw.nl
       * MIT Licensed.
       * When running in HASS.IO the address and ipWhitelist need to be
       * empty and any access mcontrols need to be on the host
       * and not in the container.
      var config = {
          address: "", // Empty as running in a docker container.
          port: 8080, // Update port in HASS.IO configuration and not here.
          ipWhitelist: [], // Empty as in docker container, ACL from the host.
          // The settings below are for a basic setup, please modifiy as needed.
          language: "en",
          timeFormat: 24,
          units: 'metric',
          customCss: "css/custom.css",
                  module: "alert",
                  module: "updatenotification",
                  position: "top_bar"
                  module: 'MMM-OnScreenMenu',
                  position: 'bottom_right',
                      touchMode: true,
                      enableKeyboard: true,
                      menuItems: {
                          notify1: {  title: "Home",
                              icon: "eye",
                              notification: "PAGE_CHANGED",
                              payload: 0 },
                          notify2: {  title: "Comics",
                              icon: "eye",
                              payload: 1 },
                          notify3: {  title: "Home Assistant",
                              icon: "eye",
                              payload: 2 }
                  module: "MMM-pages",
                              [ "calendar", "clock","weatherforecast","currentweather","newsfeed", "MMM-HASS", "MMM-homeassistant-sensors" ],
                              [ "DailyXKCD" ],
                              [ "MMM-iFrame" ]
                      excludes: ["alert", "updatenotification", "MMM-OnScreenMenu"],
                  module: 'MMM-iFrame',
                  position: 'fullscreen_below',	// This can be any of the regions.
                          url: ["http://hassio.local:8123"],
                          updateInterval: 60 * 60 * 1000,// Refresh every 60 minutes
                          width: "100%",
                          height: "1000px"
                  module: "DailyXKCD",
                  position: 'top_left',
                      invertColors: true,
                      showTitle: true,
                      showAltText: false
                  module: "clock",
                  position: "top_left"
                  header: "Swedish Holidays",
                              symbol: "calendar-check-o ",
                              url: "https://www.calendarlabs.com/ical-calendar/ics/71/Sweden_Holidays.ics"
                  module: "compliments",
                  position: "lower_third"
                  module: "currentweather",
                      locationID: "2711537",  //ID from http://www.openweathermap.org/help/city_list.txt
                      appid: "8855659590a1ea21d27d3279bddad567"
                  module: "weatherforecast",
                  header: "Weather Forecast",
                  module: "newsfeed",
                  position: "bottom_bar",
                      feeds: [
                              title: "SVT News",
                              url: "https://www.svt.se/nyheter/rss.xml"
                      showSourceTitle: true,
                      showPublishDate: true
                      module: "MMM-HASS",
                              host: "192.168.10.242", // Special docker ha api proxy
                              port: "8123",
                              https: false,
                              devices: [
                              { deviceLabel: "Exterior",
                                      deviceReadings: [
                                      { sensor: "sensor.medel_temp_ute", icon: "wi wi-thermometer", suffix: "°"},
                                      { sensor: "sensor.weather_humidity", icon: "wi wi-humidity", suffix: "%"}
                              { deviceLabel: "Interior",
                                      deviceReadings: [
                                      { sensor: "sensor.kitchen_temperature", icon: "wi wi-thermometer", suffix: "°", notification: "INDOOR_TEMPERATURE"},
                                      { sensor: "sensor.kitchen_temperature", icon: "wi wi-humidity", suffix: "%"}
      		    module: 'MMM-homeassistant-sensors',
      			    url: 'http://192.168.10.242:8123', // Special docker ha api proxy
      			    prettyName: false,
      			    stripName: false,
      			    values: [{
      					sensor: "sensor.processor_use",
      					icons: [{
      							"default": "chip"
      					sensor: "sensor.kitchen_motion_sensor",
      					icons: [{
      							"state_off": "run",
      							"state_on": "run-fast"
      					sensor: "light.sink",
      					icons: [{
      							"state_off": "lightbulb-outline",
      							"state_on": "lightbulb-on-outline"
