    i think i'm close?
    6 Posts 2 Posters 2.1k Views 2 Watching
    • F Offline
      flipfloplife
      ok – followed instructions here: https://forum.magicmirror.builders/topic/236/complete-setup-tutorial/6 by kirash4
      new pi3. everything from format card through mirror install went seemingly well (no errors that i could see) – until i type npm start. then i get
      magicmirror@2.5.0 start: ‘sh run-start.sh’
      sh run-start.sh
      (electron:4392): Gtk-WARNING **: cannot open display: :0
      npm ERR! code ELIFECYCLE
      npm ERR! code errno 1
      npm ERR! magicmirror@2.5.0 start: ‘sh run-start.sh’
      npm ERR! Exit status 1
      npm ERR!
      npm ERR! Failed at the magicmirror@2.5.0 start script.
      npm ERR! /home/pi/.npm/_logs/2018-10-22T18+03_34_626Z-debug.log
      so. i used the google. and i did the following:
      npm cache clean --force
      delete node_modules folder
      delete package-lock.json file
      npm install
      this did not change the error I’m getting. thoughts?
        sdetweil @flipfloplife
        @flipfloplife are you doing this over SSH? or if the PI is in console mode?
        MM requires graphics mode… (display:0)
        F 1 Reply Last reply Reply Quote 2
        • F Offline
          flipfloplife @sdetweil
          @sdetweil right on the pi. ok – so do i just adjust the run-start.sh to reflect device 0? i just left it the way it installed.
            @flipfloplife you could still be in text mode (console mode) vs the graphical desktop…
            xwindows is display:0, so you shouldn’t have to change anything…
            • F Offline
              @sdetweil HEY !! IT WORKS!!! THANKS @sdetweil !!! ha – first pi project – working ! (had no idea that being in console mode (now i know that word) was different than being in a console “window” (?) inside the graphical desktop — THAT clicked it) – neat :)
                @flipfloplife great!.. thanks for the feedback
