    MMM-Assistantmk2
    11 Posts 2 Posters 3.9k Views 2 Watching
    • F Offline
      fri4end
      This is the case of MMM-pages during onIdle or onActivate operation in MMM-Assistantmk2.I want to run sendNotification (“PAGE_CHANGED”, 2); but I don’t know how.
      • ? Offline
        [[global:former-user]] @fri4end
        @fri4end
        Try this;
        onIdle: {
          timer: 1000 * 30,  // in 30sec after last Assistant Query, command "PAGE_1" will be activated.
          command: "PAGE_1"
        onActivate: { //When you wakeup Assistant, command "PAGE_2" will be activated.
          timer: 0,
          command: "PAGE_2"
        command: {
          "PAGE_1": {
            notificationExec: {
              notification: "PAGE_CHANGED",
              payload: 1
          "PAGE_2": {
            notificationExec: {
              payload: 2
        I didn’t test, but this could be a help to understand.
        • F Offline
          fri4end @Guest
          @sean
          I’ve tested it,
          You will be redirected to another page instead of 1, 2.0_1544614195972_eacf22b0-19c3-4f76-9027-23240fb4433d-image.png
          • ? Offline
            @fri4end said in MMM-Assistantmk2:
            What does it mean? These commands just emit notification "PAGE_CHABGED" with payload 1(or 2), if it doesn’t work as your expectation, give me details more.
            • F Offline
              fri4end @Guest
              @sean
              Here’s what it says
              		module: "MMM-AssistantMk2",
              		position: "bottom",
              		config:
              			useScreen: true,
              			youtubeAutoplay: true,
              			responseAlert: false,
              			alertError: false,
              			pauseOnYoutube:false,
              			deviceLocation:
              				coordinates:
              					latitude: 37.57,
              					longitude: 126.98
              			profiles:
              				"default":
              					lang: "en-EN"
              			notifications:
                  				ASSISTANT_ACTIVATED: "HOTWORD_PAUSE",
              				ASSISTANT_DEACTIVATED: "HOTWORD_RESUME",
              			onIdle: {
              timer: 1000 * 30, // in 30sec after last Assistant Query, command “PAGE_1” will be activated.
              command: “PAGE_1”
                 timer: 0,
                command: "PAGE_2"
              command: {
                 "PAGE_1": {
                 notificationExec: {
                    payload: 0
              "PAGE_2": {
                 notificationExec: {
                    payload: 1
              ? F 2 Replies Last reply Reply Quote 0
              • ? Offline
                @fri4end
                So, onIdle or onActivate doesn’t work? or not your expectation?
                • F Offline
                  fri4end @fri4end
                  This post is deleted!
                  • F Offline
                    fri4end @Guest
                    @sean
                    No, onIdle and onActivate operate normally
                    We checked the status using the notification viewer module.
                    Manual operation below
                    Below, when onActivate
                    I think the payload return is incorrect.
                    ? 2 Replies Last reply Reply Quote 0
                    • ? Offline
                      @fri4end
                      Ah, I got it.And I’ve found what was wrong. Wait a min. I’ll patch for it. I assumed each payload should be object type.
                      • ? Offline
                        @fri4end
                        fixed. git pull and try again.
                        • F Offline
                          fri4end @Guest
                          @sean
                          It works well. Thank you very much.^^
