    no image on my screen
    run-start.sh not found
    2 Posts 2 Posters 625 Views 2 Watching
    • Q Offline
      qqkl662
      when i run the code “npm start”,i can not see any change in my screen,no image.
      here is the error
      (node:4533) [DEP0022] DeprecationWarning: os.tmpDir() is deprecated. Use os.tmpdir() instead.
      > magicmirror@2.5.0 start /home/pi/MagicMirror
      > sh run-start.sh
      run-start.sh: 4: run-start.sh: electron: not found
      npm ERR! magicmirror@2.5.0 start: `sh run-start.sh`
      npm ERR! Exit status 127
      npm ERR!
      npm ERR! Failed at the magicmirror@2.5.0 start script.
      npm ERR! This is most likely a problem with the magicmirror package,
      npm ERR! not with npm itself.
      npm ERR!     sh run-start.sh
      npm ERR! You can get their info via:
      npm ERR!     npm owner ls magicmirror
      npm ERR! System Linux 4.14.79-v7+
      npm ERR! command "/usr/bin/node" "/usr/bin/npm" "start"
      npm ERR! cwd /home/pi/MagicMirror
      npm ERR! node -v v8.11.1
      npm ERR! npm -v 1.4.21
      npm ERR! code ELIFECYCLE
      npm WARN This failure might be due to the use of legacy binary "node"
      npm WARN For further explanations, please read
      /usr/share/doc/nodejs/README.Debian
      npm ERR!
      npm ERR! not ok code 0
        sdetweil
        looks like you did not complete the install…
        cd MagicMirror
        npm install
        when that completes, look for node_modules/electron. is that folder present?
        if so, then try npm start again
