    MM died after reboot
    3 Posts 1 Posters 954 Views 1 Watching
    • eniacE Offline
      eniac
      And anotherone error … I think that is my last try with MM2. Have a lot of different issues and that is the last one.
      2 Month running without Problems, no reboot, no error, no frozen module … running well. But yesterday the calender Module does not update. reboot the Pi with VNC und volia … no MM anymore …
      This is what happens ->
      pi@raspberrypi:~ $ ./mm.sh
      > magicmirror@2.5.0 start /home/pi/MagicMirror
      > sh run-start.sh
      App threw an error during load
      /home/pi/MagicMirror/node_modules/express/lib/application.js:164
          onerror: logerror."ind(th)s)
      SyntaxError: Invalid or unexpected token
          at createScript (vm.js:80:10)
          at Object.runInThisContext (vm.js:139:10)
          at Module._compile (module.js:606:28)
          at Object.Module._extensions..js (module.js:653:10)
          at Module.load (module.js:561:32)
          at tryModuleLoad (module.js:504:12)
          at Function.Module._load (module.js:496:3)
          at Module.require (module.js:586:17)
          at require (internal/module.js:11:18)
          at Object.<anonymous> (/home/pi/MagicMirror/node_modules/express/lib/express.js:18:13)
      A JavaScript error occurred in the main process
      Uncaught Exception:
      That is what “sudo npm run config:check” bings back.
      pi@raspberrypi:~/MagicMirror $ sudo npm run config:check
      > magicmirror@2.5.0 config:check /home/pi/MagicMirror
      > node tests/configs/check_config.js
      /home/pi/MagicMirror/node_modules/jshint/data/non-ascii-identifier-start.js:1
      (function (exports, require, module, __filename, __dirname) { var str = ' Bunch of Numbers ! )
      SyntaxError: Unexpected identifier
          at new Script (vm.js:51:7)
          at createScript (vm.js:136:10)
          at Object.runInThisContext (vm.js:197:10)
          at Module._compile (internal/modules/cjs/loader.js:618:28)
          at Object.Module._extensions..js (internal/modules/cjs/loader.js:665:10)
          at Module.load (internal/modules/cjs/loader.js:566:32)
          at tryModuleLoad (internal/modules/cjs/loader.js:506:12)
          at Function.Module._load (internal/modules/cjs/loader.js:498:3)
          at Module.require (internal/modules/cjs/loader.js:598:17)
          at require (internal/modules/cjs/helpers.js:11:18)
      npm ERR! code ELIFECYCLE
      npm ERR! errno 1
      npm ERR! magicmirror@2.5.0 config:check: `node tests/configs/check_config.js`
      npm ERR! Exit status 1
      npm ERR!
      npm ERR! Failed at the magicmirror@2.5.0 config:check script.
      npm ERR!     /root/.npm/_logs/2018-12-21T16_48_22_625Z-debug.log
      Bunch of Numbers was blockt as Spam from Askinet.com ? I removed them …
      Any ideas ? I don’t what to bury that nice project, but it is the fifth time i have to repair that thing after an Upgrade or Update, reboot or unclean shutdown.
      • eniacE Offline
        eniac
        I think it was the SD Card. So many different Files with syntax errors so I’d mounted a Notebook HD with a Adapter and reinstalled the RaspberryOS. Gve it an new try
        eniacE 1 Reply Last reply Reply Quote 0
        • eniacE Offline
          eniac @eniac
          Up… and Running …
          Now I can hear the hadrdisk working… I don’t wounder how much access the HD does , the sd cards died quickly :(
