    Help with my calendar
    calendar
    5 Posts 2 Posters 2.0k Views 2 Watching
      richardh151
      Please can someone help me with my calendar. I would like to remove the Country name in my example “Switzerland” from each holiday line before the stated holiday event as I know they are all for Switzerland. (Switzerland:New Years Day) Where can I edit this out? Also I would like to change the font of the date on the right as I looks dimmed and I would like to modify this to white or brighter. Thanks in advance to anyone that can give me the guidance.
      • ? Offline
        [[global:former-user]] @richardh151
        @richardh151
        You can use titleReplace field in your configuration.
        For modifying font style, use CSS. add this into your css/custom.css
        .calendar .time {
          color:#FFF;
          richardh151 @Guest
          @sean Firstly the Color change of the date worked, thanks. I’m struggling to edit the titleReplace as
          any change that I do in the titleReplace part within the config.js file does not seem to have an effect or gives me a Config.js file error. Am I editing it in the correct area?
          • ? Offline
            @richardh151
                titleReplace: {"Switzerland:" : ""},
                //... other configuration
              richardh151 @Guest
              @sean Thank you Sean it works, sorry I didn’t fully understand the title replace concept. Happy new year to you.
