    Add SSL/TLS certificate
    4 Posts 3 Posters 2.1k Views 3 Watching
      MrNonoss
      Good evening everybody.
      I would like to add a security layer to my MagicMirror by setting up a letsencrypt certificate.
      I setted up an Nginx reverse proxy to access my different services at home (Synology, Home-Assistant, …) and I plan to access my MagicMirror also.
      Is It possible to do so (add certificate)? How?
      Thank you a lot guys.
      • C Offline
        cyberphox
        do you have a walkthrough on how you setup the reverse proxy server? looking to secure up my synology boxes
          sdetweil
          the code looks like its http only. (see MM/app/server.js)
          var server = require(“http”).Server(app);
          here is some good discussion on https server
          https://stackoverflow.com/questions/5998694/how-to-create-an-https-server-in-node-js
            MrNonoss @cyberphox
            @cyberphox,
            Sorry for the “New Year Delay”.
            I use docker for all my stuff.
            But besides that, I mainly used this tutorial:
            https://www.home-assistant.io/docs/ecosystem/nginx_subdomain/
            It’s about home-assistant, but the principle works for everything
            @sdetweil,
            Thank you a lot.
            That was my fear
