    sleep and wake tv with motion
    3 Posts 2 Posters 2.0k Views 2 Watching
    • C
      costascontis
      Re: [Motion Detection with RaspiCam](Non-Module version)
      i have setup motion running and mm as well.My mirror is a LGtv .I edit motion.conf like:
      # Command to be executed when an event starts. (default: none)
      # An event starts at first motion detected after a period of no motion defined by event_gap
      on_event_start vcgencmd display_power 1
      # Command to be executed when an event ends after a period of no motion
      # (default: none). The period of no motion is defined by option event_gap.
      on_event_end vcgencmd display_power 0
      that works pretty well sleeping and waking my mirror.My problem is that “vcgencmd display_power 0” doesnt blank my screen and so my tv goes into that horrible screensaver mode with the cube…
      But then playing around i noticed that giving
      /opt/vc/bin/tvservice -p
      at the Lxterminal instead of waking up my hdmi screen goes to a blank state and its like turned off!!!I thought thats nice plus typing:
      /opt/vc/bin/tvservice -p && sudo chvt 6 && sudo chvt 7
      it wakes up allright.So my linux noob thinking said lets put those commands at motion.
      on_event_start /opt/vc/bin/tvservice -p && sudo chvt 6 && sudo chvt 7
      on_event_end /opt/vc/bin/tvservice -p
      It sleeps ok like i want to but it doesnt wake up.Seems like motion “on_event_start” is giving " /opt/vc/bin/tvservice -p" and not all the command like “/opt/vc/bin/tvservice -p && sudo chvt 6 && sudo chvt 7”.
      What can i do my linux experts?
        sdetweil @costascontis
        @costascontis u should ask the motion guys. My module does all that under the covers. I posted an update cause the command execution was throwing an error.
        Well, actually, I know how…
        The & is a shell operation, so u would have to invoke sh or bash, and pass it the tvservice string u listed
        My module has the same problem, now that you mention it… I can’t fix til late today
        • C
          costascontis
          actually i got it to work,starting the motion with sudo motion -n it executes the comands just fine.My screen is turning on and off just fine.I just want to find out how to start motion with pm2 now .
