    MMM-RTSPStream works... but intermittently
    1 Posts 1 Posters 754 Views 1 Watching
    • K Offline
      kevsfastz
      Yes, another RTSPStream issues thread!
      Long story short, I’ve been running RTSPStream for years without a problem. About a month ago I wiped out my pi and started fresh with Stretch, reconfigured and even used the same config file as prior with no problems ( using the same camera and same http: link to camera). Now I have issues with my stream going blank randomly. It will work fine for a while when MM boots up then randomly will just go blank. I have spent the past couple weeks digging through this forum researching and reading all the other issue threads related but I am officially out of ideas. This is the troubleshooting I have done so far:
      Disabled GL drivers
      Tweaked config based on suggestions on other threads
      Verified Omxplayer is updated
      Verified stream works fine via VLC
      Tested with both low and high-quality feeds
      Increased GPU memory to 120
      As for logs, I can’t seem to capture any errors or red flags popping up regarding RTSPStream from the ‘mm-out.log’. The only thing I could verify is when the stream is working, omx_stream1 shows online, and offline when it goes blank. If I try to perform ‘pm2 start omx_stream1’ it will revert back to online, but the stream is still blank.
      If anyone has any idea or guidance for me I would greatly appreciate it. It seems the issue happened when switching to Stretch as everything worked perfectly with Jessie. Maybe there are more logs I don’t know of that can help pinpoint this issue?
      Here is the latest from the logs, this is current from today after waiting for the stream to go blank. All the previous logs are the same, just repetitive:
      Starting MagicMirror: v2.6.0
      Loading config ...
      Loading module helpers ...
      No helper found for module: MMM-windy.
      Module helper loaded: MMM-WatchDog
      Module helper loaded: MMM-WunderGround
      Module helper loaded: mmm-nest-status
      Module helper loaded: MMM-MyCommute
      Module helper loaded: MMM-History
      Module helper loaded: mmm-systemtemperature
      No helper found for module: MMM-pihole-stats.
      Module helper loaded: MMM-News
      Module helper loaded: MMM-RTSPStream
      All module helpers loaded.
      Server started ...
      Connecting socket for: MMM-WatchDog
      Starting module helper: MMM-WatchDog
      Connecting socket for: MMM-WunderGround
      MMM-WunderGround helper started ...
      Connecting socket for: mmm-nest-status
      Starting node_helper for module [mmm-nest-status]
      Connecting socket for: MMM-MyCommute
      ====================== Starting node_helper for module [MMM-MyCommute]
      Connecting socket for: MMM-History
      Starting module: MMM-History
      Connecting socket for: mmm-systemtemperature
      Starting node helper: mmm-systemtemperature
      Connecting socket for: MMM-News
      Connecting socket for: MMM-RTSPStream
      Launching application.
      WatchDog started. Maximum timeout: 10s.
      GET_WUNDERGROUND
      Create new calendar fetcher for url: https://calendar.google.com/calendar/ical/ketz%40gmail.com/private-2d9/basic.ics - Interval: 300000
      Create new calendar fetcher for url: https://calendar.google.com/calendar/ical/en.usa%23holiday%40group.v.calendar.google.com/public/basic.ics - Interval: 300000
      [NEWS] Initialized.
      [NEWS] Articles are aggregated :  10
      Starting stream stream1 with args: [
          "--avdict",
          "rtsp_transport:tcp",
          "--win",
          "63, 1043, 843, 1543",
          "--live",
          "--video_queue",
          "4",
          "--fps",
          "30",
          "rtsp://admin:xxxxxxxx@192.168.0.7:554/h264Preview_01_main"
      PM2: omx_stream1 already running. Stopping old instance...
      Starting PM2 for omx_stream1
      PM2 started for omx_stream1
      2019-02-13T15:09:40-05:00 6 MMM-WunderGround: null
      2019-02-13T15:19:42-05:00 6 MMM-WunderGround: null
      and the config:
                  module: "MMM-RTSPStream",
                  position: "bottom_bar",
                      autoStart: true,
                      rotateStreams: false,
                      rotateStreamTimeout: 10,
                      moduleWidth: 780,
                      moduleHeight: 500,
                      localPlayer: 'omxplayer',
                      remotePlayer: 'none',
                      showSnapWhenPaused: false,
                      remoteSnaps: false,
                      stream1: {
                          url: 'rtsp://admin:xxxxxx@192.168.0.7:554/h264Preview_01_sub',
                          frameRate: undefined,
                          hdUrl: 'rtsp://admin:xxxxxxx@192.168.0.7:554/h264Preview_01_main',
                          width: 780,
                          height: 500,o
                          omxRestart: 24,
      Thanks in advance!
