    Can't seem to get PlayStation 3 Eye Camera to work
    13 Posts 4 Posters 8.2k Views 3 Watching
    • J
      jmartin1009
      I was wondering if anyone else has had any trouble getting the PS3 eye camera to work and had a fix. It doesn’t work for me and when I use the asoundrc. method it doesn’t let me open alsamixer or use anything to check to make sure it works. I bought one bc I saw people were having success with the microphone array but I just can’t seem to get it to work correctly. All help is appreciated, thank you!
      • ChrisC
        Chris
        Hello,
        Modify your ~ / .asoundrc and /etc/asound.conf files
        sudo nano /etc/asound.conf
        sudo nano .asoundrc
        with this code:
        # ps3 eye + 3.5mm speaker Raspberry Pi
        ## Suggested by http://julius.sourceforge.jp/forum/viewtopic.php?f=9&t=66
        ## Modified by https://github.com/afzalive
        pcm.jack {
          type hw
          card ALSA
        pcm.array {
          type hw
          card CameraB409241
        pcm.softvol {
          type softvol
          slave.pcm "jack"
          control {
            name Master
            card 0
        pcm.cap {
          type plug
          slave.pcm "array"
          slave.channels 4
          ttable {
            0.0 30.0
            1.1 30.0
        pcm.!default {
            type asym
            playback.pcm "plug:softvol"
            capture.pcm {
              type plug
              slave.pcm "cap"
        ctl.!default {
          type hw
          card 0
        ctl.softvol {
          type hw
          card 0
        open a terminal and install pulseaudio:
        sudo apt-get install pulseaudio
        sudo apt-get install pavucontrol gstreamer0.10-pulseaudio
        reboot and in the menu of raspbian you should see a tab allowing you to access the pulseaudio settings (sound and video tabs).
        The PS3 mic will appear in it.
        I hope I have been clear in my indications,
        Regards,
        J 3 Replies Last reply
        Reply Quote 1
        • J
          jmartin1009 @Chris
          @chris oh wow, thank you! I’m not able to try this right now but I will give it a shot tonight, thank you so much!!
          • J
            jmartin1009 @Chris
            @chris I’m trying to do it right now but I can’t seem to find a file in etc/ named asound.conf, I can find asound.conf.swp and asound.conf.save, but it says I don’t have permission to rename, edit, or add a new file called asound.conf in the folder so idk what to do about that
            • J
              jmartin1009 @Chris
              @chris also when i tried to do the second line of the pulseaudio install, i got
              pi@raspberrypi:~ $ sudo apt-get install pauvcontrol gstreamer0.10-pulseaudio
              Reading package lists... Done
              Building dependency tree
              Reading state information... Done
              E: Unable to locate package pauvcontrol
              what do i do to fix this, thanks!
              ChrisC 1 Reply Last reply
              • yawnsY
                yawns Moderator
                It is pavucontrol, not pauvcontrol :-)
                J 1 Reply Last reply
                • J
                  jmartin1009 @yawns
                  @yawns what about the asound.conf file though? I can’t find it or create a new one to put that code in :/ but thanks for the help with the pavucontrol haha I didnt notice I read it wrong
                    sdetweil @jmartin1009
                    @jmartin1009 said in Can't seem to get PlayStation 3 Eye Camera to work:
                    asound.conf
                    that file is called .asoundrc
                    it is typically in the users home folder (/home/pi)… note that that the name starts with a dot (.)
                    • ChrisC
                      Chris @jmartin1009
                      Hello,
                      it is actually pavucontrol and not pauvcontrol as yawms rightly pointed out.
                      the .asound.conf file is a hidden file. right-click in the file explorer window and choose to show hidden files. Normally it will appear.
                      In any case, if there is no sudo nano command .asound.conf in the terminal will create this file.
                      as sdetweil tells you, stick to the point at the beginning of the file.
                      Regards,
                      • J
                        jmartin1009 @Chris
                        @chris @sdetweil @yawns I was able to edit the asoundrc file, but the .conf file wasn’t showing up as I was looking with the hidden files on, the only asound.conf files I could find were asound.conf.swp and asound.conf.save. I’m also kind of confused about how to save a new file in the terminal if I do the sudo nano method, because I was able to get into etc/ from there but it was only trying to have to overwrite a file, not create a new one, if there is a way to create a new file altogether for asound.conf, then I would like to know how to do that because it’s not appearing in hidden files and when I make the file in the terminal it seems like I can only overwrite. Thank you!
                          @jmartin1009 to make a new file, just rename the existing one to something else (asound.conf.save) and then create a new file
                          • J
                            jmartin1009 @sdetweil
                            @sdetweil when I try to edit the name of the asound.conf.save file in order to create a new around.conf file, it tells me I don’t have permission to do it, or to delete it or really do anything with the file as well as that I don’t have permission to make a new file in the /etc/ folder. What do I do?
                            • J
                              jmartin1009 @jmartin1009
                              @jmartin1009 nevermind I didn’t realize that entire time if I hit enter it would just make the file 🤦🏻‍♂️ I thought I had to go into files and everything, thank you!
