    Default Calendar // Help in tweaking the dateheaders mode
    7 Posts 2 Posters 1.8k Views 2 Watching
      bolish
      When I’m in dateheaders mode, the fulldayevents are always displayed on the start date.
      I would like it to be displayed starting today’s date even if the fulldayevent started days before.
      i.e : I’ve a fulldayevent which started on March 6th and finishes tomorrow.
      In the dateheaders view, event is displayed on March 6th date. Which I don’t want.
      What I would like is to see it in today’s + tomorrow’s header.
      I’ve already tried to modify calendar.js line 258 in several ways but don’t manage to get it done. (maybe it’s even not the right line to modify…)
      Would appreciate if someone could help me in this! Thanks already.
        sdetweil @bolish
        @bolish
        well , it should be one of these two lines, and u might want to make it configurable
        /* line 302 */								timeWrapper.innerHTML = this.capFirst(moment(event.startDate, "x").format(this.config.fullDayEventDateFormat));
        						} else {
        							// show future time relative, start of day to start of day
        /* line 306 */							timeWrapper.innerHTML = this.capFirst(moment(event.startDate, "x").from(moment().format("YYYYMMDD")));
        and the value should be
        moment(now, "x")
        instead of
          bolish
          Thanks @sdetweil
          I will try that.
          Nevertheless, it seems strange … because from my understading, everything which is between line 264 and 364 seems to be linked to “not dateheaders” format.
            sdetweil @bolish
            @bolish Ok, headers mode is really primative
            it gets the calendar entry as a string
            and puts that out…
            starting on line 159
            	for (var e in events) {
            			var event = events[e];
            			var dateAsString = moment(event.startDate, "x").format(this.config.dateFormat);
            			if(this.config.timeFormat === "dateheaders"){
            				if(lastSeenDate !== dateAsString){
            					var dateRow = document.createElement("tr");
            					dateRow.className = "normal";
            					var dateCell = document.createElement("td");
            					dateCell.colSpan = "3";
            					dateCell.innerHTML = dateAsString;    --------------
            					dateRow.appendChild(dateCell);
            					wrapper.appendChild(dateRow);
            in the area u were looking, it only does that formatting if NOT a full date event
            			if(this.config.timeFormat === "dateheaders"){  if YES
            				if (event.fullDayEvent) {
            					titleWrapper.colSpan = "2";
            					titleWrapper.align = "left";
                                                    // just fixup the style info, data posted above
            				}else{
                                                    // NOT fullday event
            					var timeClass = this.timeClassForUrl(event.url);
            					var timeWrapper = document.createElement("td");
            					timeWrapper.className = "time light " + timeClass;
            					timeWrapper.align = "left";
            					timeWrapper.style.paddingLeft = "2px";
            					timeWrapper.innerHTML = moment(event.startDate, "x").format("LT"); //only NOT fullday
            					eventWrapper.appendChild(timeWrapper);
            					titleWrapper.align = "right";
              bolish
              hi Sam @sdetweil
              I’ve tried following but I believe this is not the way to do it.
              It seems I can’t figure out how the dateheaders mode is working…
              I “only” want that fulldayevents which started earlier than today stops to be displayed in earlier dates and only starts today…
              			var dateAsString2 = moment(now, "x").format(this.config.dateFormat);
              							dateCell.innerHTML = dateAsString2;
              							} else {
              							date.Cell.innerHTML = dateAsString;
              					if (e >= startFade) {			//fading
              						currentFadeStep = e - startFade;
              						dateRow.style.opacity = 1 - (1 / fadeSteps * currentFadeStep);
              					lastSeenDate = dateAsString;
              Don’t you think that it’s maybe something to be added in line 449?
                sdetweil
                ok, I added an event, and debugged… the change is right there at the top of the loop, line 159
                					dateCell.innerHTML = dateAsString;    < --------------
                I moved the
                   var now = new Date()
                from line 272
                and have this (edited to add space behind the < )
                      var now = new Date();
                          if(event.startDate< now){
                            Log.log("calendar, event start before today, end after today "+dateAsString)
                            dateAsString= moment(now, "x").format(this.config.dateFormat);
                  bolish
                  Thanks for your support, works fine!
                  Last thing :
                  i.e : we are on March 11th.
                  fulldayevent starts on March 9th and finishes on 13th
                  Thanks to you, the event only starts to show on 11th.
                  Unfortunatly, it “only” shows on 11th. not on 12 and 13th.
                  Looking at how the dateheaders part is written, I believe it’s impossible, correct? (as the event display date is only based on one dateasstring…)
