    MMM-Wallpaper black screen
    8 Posts 3 Posters 2.5k Views 3 Watching
      sdetweil @Pocoyo
      @pocoyo see
        ccrichtx @Pocoyo
        @pocoyo
        This is my MMM-Wallpaper and use Reddit instead of bing.
        Just replace source: “/r/MoviePosterPorn”, TO source: “bing”,
        module: “MMM-Wallpaper”,
        position: “fullscreen_below”,
        classes: ‘scheduler’,
        module_schedule: {from: ‘0 6 * * *’, to: ‘0 23 * * *’ },
        maximumEntries:100,
        slideInterval: 30 * 1000,
        updateInterval: “90000”,
        filter: “grayscale(0.5) brightness(0.5)”,
        shuffle: true,
        size: “contain”, // cover,contain,auto
          ccrichtx @ccrichtx
          @ccrichtx
          You can delete these rows, they are used for MMM-Scheduler:
          and
          module_schedule: {from: ‘06 ***’, to: ‘0 23 ***’},
            Pocoyo @sdetweil
            @sdetweil I have now tried your script, but the screen is still black.
            Can you maybe do something with that?
            [07.03.2022 18:07.50.133] [ERROR] Whoops! There was an uncaught exception...
            [07.03.2022 18:07.50.139] [ERROR] Error: Cannot find module 'async'
            Require stack:
            - /home/pi/MagicMirror/modules/MMM-nasaastropic/node_helper.js
                at Module._resolveFilename (node:internal/modules/cjs/loader:940:15)
                at Function.n._resolveFilename (node:electron/js2c/browser_init:249:1128)
                at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/module-alias/index.js:49:29)
                at Module._load (node:internal/modules/cjs/loader:785:27)
                at Function.c._load (node:electron/js2c/asar_bundle:5:13331)
                at Module.require (node:internal/modules/cjs/loader:1012:19)
                at require (node:internal/modules/cjs/helpers:94:18)
                at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-nasaastropic/node_helper.js:9:13)
                at Module._compile (node:internal/modules/cjs/loader:1116:14)
                at Object.Module._extensions..js (node:internal/modules/cjs/loader:1169:10) {
              code: 'MODULE_NOT_FOUND',
              requireStack: [
                '/home/pi/MagicMirror/modules/MMM-nasaastropic/node_helper.js',
                '/home/pi/MagicMirror/js/app.js',
                '/home/pi/MagicMirror/js/electron.js',
                '/home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js',
                undefined
            [07.03.2022 18:07.50.140] [ERROR] MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
            [07.03.2022 18:07.50.141] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
              sdetweil @Pocoyo
              @pocoyo see
              https://forum.magicmirror.builders/topic/16453/mmm-wallpaper-black-screen/3?_=1646678233360
                Pocoyo
                I deleted everything again and redid it now it works, thanks for the help.
