    MMM-Wallpaper black screen
    8 Posts 3 Posters 2.4k Views 3 Watching
      Pocoyo
      Hello all,
      I have the problem, when I insert the MMM Wallpaper module from kolbyjack I have only a black screen with a mouse courser. Can anyone tell me what I am doing wrong.
                     module: "MMM-Wallpaper",
                     position: "fullscreen_below",
                              // See "Configuration options" for more information.
                             source: "bing",
                             slideInterval: 5 * 60 * 1000, // Change slides every minute
        Pocoyo
        I deleted everything again and redid it now it works, thanks for the help.
          Pocoyo
          I do not get it. I checked the config.js with npm run config:check. No syntax error. Deleted the module and tried MMM-nasaastropic instead. The same result. A black screen, I see only the courser. Config.js checked, no synatx error
          S C 2 Replies Last reply Reply Quote 0
            sdetweil @Pocoyo
            @pocoyo see
              ccrichtx @Pocoyo
              @pocoyo
              This is my MMM-Wallpaper and use Reddit instead of bing.
              Just replace source: “/r/MoviePosterPorn”, TO source: “bing”,
              module: “MMM-Wallpaper”,
              position: “fullscreen_below”,
              classes: ‘scheduler’,
              module_schedule: {from: ‘0 6 * * *’, to: ‘0 23 * * *’ },
              maximumEntries:100,
              slideInterval: 30 * 1000,
              updateInterval: “90000”,
              filter: “grayscale(0.5) brightness(0.5)”,
              shuffle: true,
              size: “contain”, // cover,contain,auto
                ccrichtx @ccrichtx
                @ccrichtx
                You can delete these rows, they are used for MMM-Scheduler:
                and
                module_schedule: {from: ‘06 ***’, to: ‘0 23 ***’},
                  Pocoyo @sdetweil
                  @sdetweil I have now tried your script, but the screen is still black.
                  Can you maybe do something with that?
                  [07.03.2022 18:07.50.133] [ERROR] Whoops! There was an uncaught exception...
                  [07.03.2022 18:07.50.139] [ERROR] Error: Cannot find module 'async'
                  Require stack:
                  - /home/pi/MagicMirror/modules/MMM-nasaastropic/node_helper.js
                      at Module._resolveFilename (node:internal/modules/cjs/loader:940:15)
                      at Function.n._resolveFilename (node:electron/js2c/browser_init:249:1128)
                      at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/module-alias/index.js:49:29)
                      at Module._load (node:internal/modules/cjs/loader:785:27)
                      at Function.c._load (node:electron/js2c/asar_bundle:5:13331)
                      at Module.require (node:internal/modules/cjs/loader:1012:19)
                      at require (node:internal/modules/cjs/helpers:94:18)
                      at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-nasaastropic/node_helper.js:9:13)
                      at Module._compile (node:internal/modules/cjs/loader:1116:14)
                      at Object.Module._extensions..js (node:internal/modules/cjs/loader:1169:10) {
                    code: 'MODULE_NOT_FOUND',
                    requireStack: [
                      '/home/pi/MagicMirror/modules/MMM-nasaastropic/node_helper.js',
                      '/home/pi/MagicMirror/js/app.js',
                      '/home/pi/MagicMirror/js/electron.js',
                      '/home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js',
                      undefined
                  [07.03.2022 18:07.50.140] [ERROR] MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                  [07.03.2022 18:07.50.141] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                    sdetweil @Pocoyo
                    @pocoyo see
                    https://forum.magicmirror.builders/topic/16453/mmm-wallpaper-black-screen/3?_=1646678233360
                      Pocoyo
