Solved install MM2.18 on win10 pc
Re: Installing Magic mirror on windows 10
Hi, trying to run MM on a win10 PC - followed the instructions from Mykle1
but when I run npm start I get following message
image url)(I already removed DISPLAY… from Package.json)
how to fix this?
@johans see this issue comment
https://github.com/MichMich/MagicMirror/issues/2779#issuecomment-1011124060
@sdetweil - thanks for the info. now it is working fine .
I got MM working under Win10 and most of the apps are working.
but in the end I prefere more the linux, so I installed debian, git, nodejs, and MM.
When to start the MM i get following message
Although I updated the package.json file and corrected accoring the instructions, I still get an error message.What else is missing?
well, the output says that the \ wasn’t right as it removed all the slashes and made 1 big string…
because u posted screenshots and not text I can’t show more
what node/npm versions did u install ??
npm -v
node -v -
npm is version 8.5.2
node = 17.7.2 -
@sdetweil said in install MM2.18 on win10 pc:
Do you want the content of the package.json file?
{ "name": "magicmirror", "version": "2.18.0", "description": "The open source modular smart mirror platform.", "main": "js/electron.js", "scripts": { "start": "node_modules\\.bin\\electron js\\electron.js", "start:dev": "DISPLAY=\"${DISPLAY:=:0}\" ./node_modules/.bin/electron js/electron.js dev", "server": "node ./serveronly", "install": "echo \"Installing vendor files ...\n\" && cd vendor && npm install --loglevel=error", "install-fonts": "echo \"Installing fonts ...\n\" && cd fonts && npm install --loglevel=error", "postinstall": "npm run install-fonts && echo \"MagicMirror installation finished successfully! \n\"", "test": "NODE_ENV=test jest -i --forceExit", "test:coverage": "NODE_ENV=test nyc --reporter=lcov --reporter=text jest -i --forceExit", "test:electron": "NODE_ENV=test jest --selectProjects electron -i --forceExit", "test:e2e": "NODE_ENV=test jest --selectProjects e2e -i --forceExit", "test:unit": "NODE_ENV=test jest --selectProjects unit -i --forceExit", "test:prettier": "prettier . --check", "test:js": "eslint 'js/**/*.js' 'modules/default/**/*.js' 'clientonly/*.js' 'serveronly/*.js' 'translations/*.js' 'vendor/*.js' 'tests/**/*.js' 'config/*' --config .eslintrc.json", "test:css": "stylelint 'css/main.css' 'fonts/*.css' 'modules/default/**/*.css' 'vendor/*.css' --config .stylelintrc.json", "test:calendar": "node ./modules/default/calendar/debug.js", "config:check": "node js/check_config.js", "lint:prettier": "prettier . --write", "lint:js": "eslint 'js/**/*.js' 'modules/default/**/*.js' 'clientonly/*.js' 'serveronly/*.js' 'translations/*.js' 'vendor/*.js' 'tests/**/*.js' 'config/*' --config .eslintrc.json --fix", "lint:css": "stylelint 'css/main.css' 'fonts/*.css' 'modules/default/**/*.css' 'vendor/*.css' --config .stylelintrc.json --fix", "lint:staged": "pretty-quick --staged", "prepare": "[ -f node_modules/.bin/husky ] && husky install || echo no husky installed." },
I also installed MM on Ubuntu V20.4 and I have exactly the same message as I get on Debian.
@sdetweil On Ubuntu I used node 16.14.2 and npm 8.5.5 while on Debian I used node 17.7.2 and npm 8.5.2. And both seems to give me the same error message
